stirred vessel
hi all,
i'm new with cfx and i'm trying to simulate a multiphase liquid-liquid stirred tank. i began with a simple single phase model, but the solver fails because it finds a non zero normal component of the velocity of the rotating mixer shaft. this is due, I think, to the low quality triangular mesh of the shaft itself, which doesn't reproduce the curvature of the cylindrical element. Is there any mesh method to overcome this problem? i tried to convert the 3 node surface tri element with a 6 node surface element, but it seems that ICEM can't generate the volume mesh elements. I've attached the icem cfd file. Anyone can help me? Best Regards, Francesco |
CFX (or just about any other CFD solver) cannot use "high order elements" like FEA does, so forget about the 6 node surface elements. Finite volume CFD solvers put the high order numerics in the discretisation scheme, not the element formulation. |
