cfx5stop error
Old   March 17, 2009, 08:45
Exclamation cfx5stop error
Xue-Guan Song
songxguan is on a distinguished road
Hello everybody,
This is my first time to post after CFD online changed the theme. It looks very nice.
I have a problem to solve, wish somebody can help me.
I run a transient model, and after a little long time (40 hours), i used the "stop" button to stop it, (since i thought the time is enough), unfortunately, it can not produce the .res result file.
a stop request has already been sent to the ANSYS CFX Solver process running in the specified directory: G:\aaa\aaa.dir
Is there someone know why this happend? and how to fix it.
Thanks in advance.
songxguan is offline   Reply With Quote
Old   March 17, 2009, 11:12
cfdguy's Avatar
cfdguy is on a distinguished road
It looks like something else happened. The cfx5stop command is fine. Was it any CPU still working or was it just freezed?
Cheers!
cfdguy is offline   Reply With Quote
Old   June 23, 2010, 03:35
julien
jehan is on a distinguished road
I have the same problem, except that I ran a steadystate run ( in HP MPI local parallel , 2 cores) through the console mode.
I used the cfx5stop command to stop the run, which was quiet efficient as it killed the job in the middle of a loop iteration....
And no result file has been created, could someone help please?
jehan is offline   Reply With Quote
Old   June 23, 2010, 08:23
cfx5stop should exit gracefully and give a results file. Are you sure nothing else is wrong, such as disk space or network error?
Old   June 23, 2010, 08:49
julien
I tried with other input files (such as those created to follow the tutorials given by ansys) and there is no problem : the folder.dir is transformed into a result file just after the process is interrupted : /
It looks like the problem is linked with the current run. For instance I haven't spotted network problem and I have enough room on the hard drive.
I have contacted ANSYS support, if they solve the problem I'll post the solution.
Old   July 29, 2010, 14:18
Saima
Saima is an unknown quantity at this point
I got error in runing def file in batch mode.
I am using command:
C:\Users\sanaz\Desktop>"C:\Program Files\ANSYS Inc\v121\CFX\bin\cfx5solve" -def Rotor_67.def
It produce my result file but it also give the messgae:
"Feature CFX_SOLVER_BASIC_MP_LIMIT does not exist in the ANSYSLI pool."
Acutally i mam using batch mode in iSIGHT optimization software this software stop after getting this messgae it takes as an error.
Saima is offline   Reply With Quote
Old   July 5, 2011, 04:39
Smile
mohammad
mohammad is on a distinguished road
Hi jeha,Hi everbody...
I have the same problem..I enter the command line "cfx5stop -<folder>.dir"
it does not work...the run continues ...do you know how to solve it?
regards
mohammad is offline   Reply With Quote
Old   June 26, 2012, 11:23
Default worked for me
Domenico
c120613 is on a distinguished road
Hi Guys,
I'm using CFX14.0 and in my case worked by writing in the command line the following:
cfx5post -directory <directory_name>.dir
I hope it will work for you too
Cheers
Domy
c120613 is offline   Reply With Quote
strange fluent error: Primitive Error at Node 0 Jean-Baptiste FLUENT 8 June 14, 2022 11:11
Error: Floating point error: invalid number fpingqian FLUENT 4 February 8, 2012 01:20
"Error: Floating point error: invalid number" MI Kim FLUENT 2 January 4, 2007 10:00
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 08:48
Error: Floating point error: invalid number Bob FLUENT 3 June 3, 2005 18:11
