tutorials spray dryer
I have done the tutorial spray dryer.But i am confused about some points.
In the tutorial,a continuous gas named Gas mixture containing H2O and Air ideal gas is created.And a binary mixture of H2O and H2Ol is also created. According to the tutorial, when i insert the air inlet boundary, i just set Basic settings & Boundary details. I am confused how do computer know what exactly flows in the domain as i do not set about it. Am i clear? I hope some would reply, thank you sincerely. Leo |
Anyone,please?
I am not sure, but I suspect it then uses the default values. The defaults are probably a mass fraction of zero, so pure air.
Glenn,thank you again.
I checked the setting,and you are right. In the boundary settings , the H20 mass fraction is 0,so its pure gas. I found the reason why i am confused before.The liquid water enteres the domain with pure gas,and they enter the domain with the same velocity.Previous, i assumed there is only liquid water in the water nozzel. It is interesting that it confused for some time. |
