Home > Forums > CFX
Some questions about CFX
Old   June 26, 2012, 01:54
Default Some questions about CFX
Stefan
shanxuewenjdx is on a distinguished road
As illustrated by the picture,does the arrows direction of "outlet" mean the fluid flow direction or pressure direction? (if I set the "boundary type" as 'OUTLET' on the left side and its "mass and momentum" as "total static pressure:20MPa")
shanxuewenjdx is offline   Reply With Quote
Old   June 26, 2012, 01:56
Stefan
And this the picture metioned above.
Old   June 26, 2012, 09:40
monkey1 is on a distinguished road
I'm sorry if I didn't get the question right, but if I did...how do you want a Fluid Flow going in an another Direction than the pressure??? Meaning if the Pressure is oriented to a specific direction then the fluid flow will also be oriented that way....the fluid flowing from the high to the low pressure domain...
Or am I just not getting the question or just being stupid and forgetting my physics?
monkey1 is offline   Reply With Quote
Old   June 26, 2012, 09:57
Peter Galimutti
p.galimutti is on a distinguished road
Originally Posted by shanxuewenjdx View Post
As illustrated by the picture,does the direction of "outlet" mean the fluid flow direction or pressure direction? (if I set the "boundary type" as 'OUTLET' and the "mass and momentum" as "total static pressure:20MPa")
how do you know total pressure at outlet. total pressure is sum of static plus dynamic pressures, you get that info after flow field is solved not before. you can only get for inlet. it leads to instabilities, see cfx help on boundary conditions.
The pressure and velocity are coupled, unless you know the velocity or pressure at the outlet it's always set as static pressure and the velocity is implicitly calculated.
You may need to rephrase your question in a better way if this is not the answer you are looking for!
p.galimutti is offline   Reply With Quote
Old   June 26, 2012, 10:07
OJ
oj.bulmer will become famous soon enough
I believe that in CFX-Pre, the direction shown is symbolic of the boundary condition, rather than what would actually happen for that situation.
So, for "outlet" you see an arrow going out, for "opening" - arrows towards both sides (as back flow is allowed in "opening"), for wall - no arrows and so on.
Essentially, in your case, even if you specify velocity at outlet as say (u,v,w) = (0,0,-2 m/s), you still will see the arrow going out.
oj.bulmer is offline   Reply With Quote
Old   June 26, 2012, 21:45
Default another question
Stefan
Could these four fluid areas be set in one "Fluid Domain"?
Old   June 27, 2012, 04:17
Peter Galimutti
outlet velocity is calculated by the solver
Old   June 27, 2012, 04:25
Stefan
Thanks.
But if I only set parameters at inlet,and neglect the outlet.(And if I choose the outlet, I have to set paramerters at outlet) How would I know the situation at outlet?You know, it won't be nearly as same as the real situation.
Old   June 27, 2012, 22:48
Stefan
You mean the outlet should not be set as anything? The cfx-help told me that it should be set as nothing only on the condition that it's supersonic,but in reality it is subsonic.As recommended in cfx-help, I set inlet:0mpa,outlet:2.667kg/s according to real situation.But it still can't be right.
Thread Tools
Trackbacks are On
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 08:08
heat generation in CFX Ema CFX 4 August 7, 2009 05:39
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 11:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
