ANSYS CFD-Post scripting - Extract Results
I need to run a large number of simulations based on very similar conditions, with slightly different meshes.
I have managed to create the python script that sets up each simulation and creates the solution, however, I am not sure what code to use in order to extract information from the results. What I want, is the Mass Flow on outlet for example (which, in the GUI is obtained through Calculators --> Function Calculator) Is there a way to extract this value without accessing the GUI? (I don't have much experience with ANSYS Scripting / Python, so any help would be great). Thanks |
Simple: put a monitor point in the simulation to return the mass flow on your outlet. Then use the cfx5mon command to get the data from the command line (or in your case a python script)
Great, thanks for that.
I have actually found an alternative which is equivalent to using the function calculator if the following is saved as batchtest.cse in the same folder as the .res file: ! $filePath = getValue("DATA READER","Current Results File"); ! $Pout = massFlow("inlet"); ! print "\nPressure at inlet is $Pout\n"; it can then be executed in cmd using: cfx5post -batch batchtest.cse runName_001.res (ensure that cfx5post is added to the current path) that way, any of the 'Function Calculator' options can be executed by changing the middle line |
I have successfully obtained average area pressure values with areaAve("Total Pressure",$surface); Now, I want to get the torque value on a surface. what command should i use? I have tried Torque_X($surface); in all possible cases and without the underscore as well. I used the variable for the surface as I have multiple surfaces to get the reading from. Cheers! |
torque($surface, x); worked !!! The syntax is listed in http://orange.engr.ucdavis.edu/Docum.../CFX/fpref.pdf |
Thanks
Thank you, this command helped me big time.
