July 19, 2005, 09:56 |
Binary Diffusion Coefficient
Hi everyone!
Does anybody has experience in setting binary diffusion coefficient for Kinematic Diffusivity in CFX 5.7.1? I read about USEDIF fortran subroutine but is not supported on this release of CFX (it's for CFX4 only). Thanks in advance for any suggestion. |
July 22, 2005, 10:01 |
Re: Binary Diffusion Coefficient
Constant diffusivity is set under the fluid properties. If you want a variable diffusivity, set it to a CEL variable, and calculate the variable value in CEL as a function of temperature, etc.
Jeff |
July 26, 2005, 04:04 |
Thank you Jeff!
Can you also suggest a source (or more than one) for appropriate diffusion coefficient values for methane-air combustion? I found some data on the web but not sure about that. I'm simulating combustion of methane-air mixture including CHT effects with solid. In some cases simulations shows flashback phenomena, not in according with sperimental data. So i'm trying to find a way to raise the flame front (which usually is really low in simulations) in order to avoid flashback (maybe due to inappropriate transport properties description of the species). Is this reasoning correct? What else could raise flame front? Thanks. |
July 1, 2012, 13:11 |
hello dear jeff
I want to simulate combustion of h2/air in fluent and I really need to its transport properties. have u any data about like chemKINE file. best regards. |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
binary diffusion coefficient / | kevin | FLUENT | 3 | July 1, 2012 13:07 |
Error to re-open fluent case file | J.Gimbun | FLUENT | 0 | April 27, 2006 08:42 |
binary diffusion coefficient | kevin-change | FLUENT | 2 | October 1, 2002 06:02 |
Who can write the binary diffusion coefficient ?? | Hsin-Ping | FLUENT | 1 | April 15, 2002 02:22 |
