Ansys 13 Workbench in UNIX/LINUX
Old   July 4, 2012, 07:37
Default Ansys 13 Workbench in UNIX/LINUX
OJ
oj.bulmer will become famous soon enough
Hi
I am trying to use Ansys products throuh LINUX machine in my university. I can start CFX and Fluent by typing commands like cfx5 and fluent directly, but don't know the command for Workbench.
Can somebody help?
Thanks
OJ
oj.bulmer is offline   Reply With Quote
Old   July 4, 2012, 10:27
monkey1 is on a distinguished road
Is this of any help to you maybe?
http://www.padtinc.com/blog/post/201...13onLinux.aspx
saying workbench starts with the command
./runwb2
out of the /ansys_inc/v130/Framework/bin/Linux64 path...
ok this is for 64bit systems but with 32 should work as well only with appropriate paths...
monkey1 is offline   Reply With Quote
Old   July 4, 2012, 11:39
OJ
Yes, I also stumbled upon that but I didn't know the installation directory. And since the runwb2 command has not been added in configuration file in UNIX, using it from anywhere doesn't help, like for CFX or Fluent, wherein you don't need to be in that directory. Just cfx5 or fluent is enough to open it.
Upon searching a little, finally found the directory and now things are working.
Thanks for the suggestion though
OJ
workbench linux
ANSYS Workbench on "Uncertified" Linux Distros hsr CFX 289 April 20, 2023 09:23
[ICEM] what does the different ANSYS ICEM and ANSYS Workbench? agungwp ANSYS Meshing & Geometry 8 April 12, 2016 04:51
Macro command combatibility ANSYS workbench Tassos CFX 6 January 13, 2014 04:19
Ansys workbench problem Jonny6001 ANSYS 2 September 30, 2010 12:59
Export Heat Flux CFX -> ANSYS Workbench Freeman CFX 2 April 11, 2010 08:24
