Home > Forums > CFX
CFX in UNIX
Old   July 5, 2012, 12:29
Default CFX in UNIX
OJ
oj.bulmer will become famous soon enough
Hello
I am trying to remotely access a LINUX system at my university using secure shell access.
I try with cfx5 or fluent after logging in to system but I get following messages:
launcher1 : cannot connect to X server
Any ideas?
oj.bulmer is offline   Reply With Quote
Old   July 5, 2012, 18:29
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
You will need a x-windows client on your PC. If you are using windows the most common x-win client is cygwin. You may also need to have certain ports open to connect.
ghorrocks is online now   Reply With Quote
Old   July 6, 2012, 05:14
OJ
Glenn, thanks.
I am using MobaXterm utility that has free in built X-server.
Additionally, I downloaded and installed XMing and XWindowsdoc, since mobaxterm wasnt working.
I will try cygwin as well, but I believe I already have three X-server applications installed! Am I missing something here?
Cheers
OJ
Old   July 6, 2012, 06:30
I have only a little experience in X servers so cannot help you. Hopefully somebody else can help you.
Old   July 12, 2012, 16:41
OJ
I solved my problem. Here is what I did, for anyone who may find this useful in future. All the bold words are the commands for UNIX.
1) Ideally you need to be in the network the UNIX machine is using, or should be connected through VPN.
2) If neither, and you are connected through normal internet, you should check what is the value of DISPLAY variable, by echo $DISPLAY
3) If it is something like localhost:12, you need to set display variable to your ip address as export DISPLAY=<your_ip_address>:0.0, by using your ip address in this command (excluding <> brackets)
4) Mobaxterm is extremely easy to use, but it is not robust. My problems got resolved when I tunnelled through Putty, enabled X11 forwarding in ssh options, and used cygwin xwin server. cygwin is more robust than XMing and beats Mobaxterm in stability. It can be found here : http://x.cygwin.com/docs/ug/setup-cy...nstalling.html
5) Make sure the Xwin server (cygwin) is running. You can check that by xeyes &, after which two eyes popup in X window, following the cursor. This is the indication that everything is going smooth.
6) If you wish to use multiple programmes, try konsole, wherein you can use as many shells (or tabs) to run the programs.
7) You may want to use WINSCP for easier file transfer within UNIX machine and your Windows.
Hope this helps someone who is stuck by UNIX chaos!
Cheers
Thread Tools
Trackbacks are On
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 10 December 11, 2015 20:52
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 08:08
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 11:59
