2D Profile Data Initialization Problem for Transient Setup
Old   July 10, 2012, 05:43
Default 2D Profile Data Initialization Problem for Transient Setup
deniz is on a distinguished road
Dear All,
I have an inlet temperature profile defined in radial and circumferential coordinates for a 45 degree section of a turbine.
Whenever I try to initialize my inlet boundary with this, either I am getting an empty contour (in cfx 13) or I am getting a plot which is nonsense and completely different than my original temperature profile plot (in cfx 14).
The model is produced with "mesh transformation/turbo rotation" and inlet is defined as the whole inlet of passages.
I do not think that there is a syntax error with csv file.
Also I cannot use "insert function" because my inlet does not stand perfectly perpendicular to rotation axis (this is why I cannot put just 0 for the 3rd coordinates)
What can be the problem? Or by which alternative method I can achieve this initialization? I would be happy if you share your ideas.
Thank you very much.
Deniz
deniz is offline   Reply With Quote
Unsteady Boundary Profile with data file Arianna FLUENT 34 July 29, 2019 16:35
OpenFoam to Fluent data conversion Problem vemps OpenFOAM 1 August 8, 2011 02:30
applying profile data as a boundary condition vadivel CFX 1 June 9, 2007 07:11
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
CFXSolver Error Message using Profile Data on B Tobias CFX 0 August 26, 2005 07:27
