Home > Forums > CFX
Easy way to export monitor data from CFX out file
Like Tree3Likes
Old   October 23, 2013, 08:06
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Rather than a true line you can do this with a long thin solid region, then use the volumeInt() function. That will work just fine, but you will need to generate a mesh with the long thin mesh region in it.
Old   October 23, 2013, 08:12
Paul
Lilienthal is on a distinguished road
Thanks for your advice.
I believe the solid region would have an influence on the flow? Otherwise I should give this a try.
Lilienthal is offline   Reply With Quote
Old   October 23, 2013, 08:20
No, I did not say a solid region. I recommend a mesh region which is made contiguous with the rest of the mesh, and will be included in the fluid domain. It will have no affect on the flow. It is just putting a label on a mesh volume so you can calculate some values on it.
Old   October 23, 2013, 08:30
Paul
Actually you said solid region But lets not get stupid here. I think I get what you mean. So I'll define a mesh volume consisting of a line of cells in the grid generator and use that as a monitoring region in cfx. Thanks a lot!
Old   October 23, 2013, 17:13
I did, didn't I... I meant a solid region of mesh (which you define as part of the fluid domain), not a domain which you define as a solid. I did not state that very clearly at all.
But I think you get the idea. Give it a go and it should work.
Thread Tools
Trackbacks are On
2.0.x on Mac OSX niklas OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 74 March 28, 2012 16:46
Version 15 on Mac OS X gschaider OpenFOAM Installation 120 December 2, 2009 11:23
Compiling gmshFoam with OpenFOAM-1.5 BlGene Open Source Meshers: Gmsh, Netgen, CGNS, ... 10 August 6, 2009 04:26
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
File export from CFX 5.3 Sinjae Hyun CFX 1 July 12, 2000 09:20
