July 15, 2012, 07:13 |
Model a Perforated Cone: Please help
S.Bogoda
Rep Power: 13 |
Dear All,
I am going to model a perforated cone. The flow (gas) transports through a perforated cone. 01. As the cone diameter varies with streamwise direction, do I want to specify 'loss model' along streamwise direction? 02. How can I get empirical formulas for Resistance Coefficient? I would be much grateful if you can help me to clarify those. Thanks. |
July 15, 2012, 08:17 |
Rep Power: 143 |
You can get information on resistance coefficients from manufacturers of this equipment or your own test data. You can also estimate it from basic fluid mechanics - for instance assuming perforations behave like lots of little oriface flows in parallel. Expect a large margin of error when you do this, of course.
July 15, 2012, 09:58 |
S.Bogoda
Rep Power: 13 |
Dear ghorrocks,
Thanks a lot for the reply. Actually, the applying a perforated cone is to increase the pressure drop and so I don’t have more data. Ok, I’ll try with your suggestion. Thanks again. |
July 15, 2012, 18:41 |
Rep Power: 143 |
Oh yes, and of course there is another option - do a simulation of the actual perforated design just to get the resistance of it, then use that resistance in a larger system model.
July 16, 2012, 22:29 |
S.Bogoda
Rep Power: 13 |
Dear ghorrex,
Thanks again for your sugssion. I desided to do experiments and try to get the resistance. I will try CFX model after then. Thank you very much. |
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 02:08 |
2 stage axial turbine model convergence issues | sherifkadry | CFX | 2 | September 7, 2009 20:51 |
flow in perforated pipe distributor | pertupd | ANSYS | 0 | August 12, 2009 08:36 |
multi fluid mixture model issue | rystokes | CFX | 3 | August 9, 2009 19:13 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 03:27 |
