-   -   flow analysis of a submerged water turbine in Ansys 13 (http://www.cfd-online.com/Forums/cfx/105360-flow-analysis-submerged-water-turbine-ansys-13-a.html)
Anwerizer July 28, 2012 13:06
I am a final year engineering student. My final year project is to analyse the water flow over a water turbine (SHP water turbine......you can check it out on their website http://www.smart-hydro.de/en/product/turbine.html ) used in mini-hydropower projects.
I have modeled the turbine in solid edge and also modeled a cylindrical water body and assembled it together with the water turbine. i used ansys 13 workbench to import this whole turbine-water assembly(in parasolid format) in the cfx analysis system. I want to know how to capture the flow stream lines using the rest of the cfx steps.
SO that includes:
1. should i mesh the water body only and leave the turbine as a solid. if yes then how can i do that?
2. How and what boundary conditions to apply?
ghorrocks July 29, 2012 07:27
Yes, mesh the water body only. Do not mesh the turbine. Model the turbine as a cavity in the mesh in a rotating frame of reference.
Boundary conditions can be many different types, but a common approach is upstream boundary condition should be the flow velocity. Down stream BC zero pressure.
Anwerizer July 29, 2012 07:40
ok....i got everything u said except the part about rotating frame of reference.......how can i define that? thanks for replying by the way
ghorrocks July 29, 2012 07:49
Rotating frames of reference is the nromal way of modelling rotating machinery. Have a look in the tutorials. There are plenty of examples of turbines and compressors. Also have a look at the best practises guide in the documentation.
Nealcaffrey September 17, 2014 08:54
Hi...Mohammed Anwer...how was your simulation btw..I am interested in your report if you dont mind...i would like to do a similar simulation on SHP Turbines.
Thanks.
