CFX solver error
i am trying to simulate 3D model of fluid flow(velocity=2m/s) over a flat plate(thickness=5mm,length=100mm.width=100mm) while running in CFX solver i am getting following error ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine FPX: C_FPX_HANDLER | | | | Help me to solve this problem |
This is probably an overflow error:
http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F |
First you should check the mesh. Then the boundary conditions are very important. If you explain all that it would be helpful. See this for flat plate help. http://www.cfd-online.com/Forums/cfx...lysis-cfx.html Would u mind telling me whether it is a random problem, or you are trying to validate some research paper. Thank you Regards Hamed |
