quetsion
When do a transient simulation,i.e,with fluctuation pressure inlet boundary,we tend to use the stead result as the initial values.But,in fact, it is not the real initial value.
So we should let the simulation run for several cycles until the the values of the monitored point are nearly the same at the corresponding time between two cycles. It is right? |
thank you!
