what's the problem
Details of error:-
---------------- Error detected by routine PSHDIR CDRNAM = /FLOW/CONTROL/OUTPUT/TRNSTAT CRESLT = NONE Current Directory : /FLOW/SOLUTION/TSTEP2/CLOOP44/ZN1/BELG7/IP/TRNAVG +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ Details of error:- ---------------- Error detected by routine FNDFIL CFNAME = * CRESLT = OLD Current Directory : /FLOW/SOLUTION/TSTEP2/CLOOP44/ZN1/VERTICES +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | The following transient and backup files written by the ANSYS CFX | | solver have been saved in the directory I:\10Hz30Hz3\10Hz30Hz_001: | | | | 1_full.bak, 1.trn, 0.trn | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Error reported by IO module: setfilebusyflag: more than one user | | is reading I:\10Hz30Hz3\10Hz30Hz_001.dir\crash or the wrong lock | | file I:\10Hz30Hz3\10Hz30Hz_001.dir\crash.lck exists | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Error reported by IO module: iocnt: setfilebusyflag failed when | | writing a data set | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Error from IO module while writing G/MON:EVERY:1: | | | | "iocnt: setfilebusyflag failed when writing a data set" | | | | IO_LOCKED(21): File is locked. Remove the lock (lck) file if this | | shouldn't be the case. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Warning! | | | | The ANSYS CFX Solver has written a crash recovery file. This file | | has been saved as I:\10Hz30Hz3\10Hz30Hz_001.res.err and may be an | | aid to diagnosing the problem or restarting the run. More details | | should be available in the solver output section of the output | | file. Note that a lock file was left for the crash file when the | | solver exited, and so it is probably incomplete. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | I:\10Hz30Hz3\10Hz30Hz_001: | | | | solver.setup, mon | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. |
The error is almost always with the first report. In this case it looks like the calculation of the transient average failed. Check it is set up correctly.
