CFX heat transfer through house wall
Old   August 5, 2012, 16:57
Default CFX heat transfer through house wall
Alen Grgic
AGrgic is on a distinguished road
I need to solve this problem for my college assignment.
I'have been trying to simulate heat transfer through wall which is formed from two layers of mortar (one inside house and one outside house), and third layer is brick wall. Outside temperature is -10 °C, and inside temperature is 20 °C.
All materials properties are used from CFX library. The thickness of mortar is 30 mm, and the thickness of brick wall is 250 mm. I created geometry using Autodesk Inventor. The geometry is formed from air inside house (1000x1000x1000 mm), air outside house (1000x1000x1000 mm), brick wall (250x1000x1000 mm), and two layers of mortar (300x1000x1000 mm) as on picture. picture.jpg
I managed to create mesh, but i have problems with domains, and boundary conditions...
Does someone know good tutorial for this kind of problem? Any sugestions how to solve this problem? anything?
Sorry for my bad english!
AGrgic is offline   Reply With Quote
Old   August 5, 2012, 19:20
Firstly, isn't this a simple 1D thermal resistance calculation? Why do it using CFD at all?
Assuming you want to do it by CFD because your college told you so :
Do the tutorial examples on Conjugate heat transfer (CHT) models. The heater coil is an example of this.
Old   August 6, 2012, 08:39
Alen Grgic
I know it is 1D thermal resistance calculation, but as you assumed my college professor told me to this way.
Thanks for the tip which tutorial to use...
heat transfer, wall heat transfer
UDF to change heat transfer coefficient with wall temperature emmkell Fluent UDF and Scheme Programming 18 August 7, 2018 03:44
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
HELP - Wall Heat Flux CFX Karkoura CFX 5 March 29, 2011 12:44
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 15:35
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
