Question about coarsening the mesh to improve convergence |
August 10, 2012, 17:43 |
Meimei Wang
Rep Power: 15 |
Hi
I have vortex at some domains of my case. The FAQ suggests me to coarsen the mesh to improve the convergence. But that will decrease the accuracy. Is there any other ways to improve the convergence for this problem?
Best regards, Meimei |
August 11, 2012, 00:56 |
Sainath
Rep Power: 13 |
Only way you are going to capture vortices is through a fine mesh. Let me know what you are trying to model. Let me see if i can helpyou out
August 11, 2012, 06:40 |
Meimei Wang
Rep Power: 15 |
Sorry, I'm not allowed to reveal that geometry. But do you mean that I can solve this problem by refining the mesh and match the mesh with the fluid behavior?
August 11, 2012, 07:31 |
Sainath
Rep Power: 13 |
If you are planning to capture vortex formation and shedding you need to have a fine mesh such that it is captured. Very small eddies can also be captured using sub grid scale type of modeling.
But there are constraints like you need to have a good computational power. Using a LES or DES model is going to be computational intensive. So plan accordingly. O If your aim is something else and vortices are formed just as the side effects of the problem then you can refine the mesh only in those are and can go in with a coarse mesh in the other areas. I really do not know what your problem is, these are just requirements for capturing vortices. Also go through the FAQ's, you may find some more tips to find effective convergence and accuracy. |
August 12, 2012, 02:56 |
Rep Power: 14 |
It isnt always required for your residual to converge. If capturing vortex is not important then you can use monitor plots like mass flow, pressure to see if you have achieved fair enough convergence.
August 12, 2012, 09:03 |
#6 | |
Rep Power: 143 |
August 12, 2012, 14:25 |
Meimei Wang
Rep Power: 15 |
I only care about the pressure drop. I don't care about the vortex at all. But I'm wondering if I don't solve the vortex, could the simulation pressure drop results still be accurate?
August 12, 2012, 14:30 |
#8 | |
Meimei Wang
Rep Power: 15 |
A physical instability, such as vortex shedding - the fix here is to use a larger timescale, a coarser mesh in the vortex shedding region, decrease the blend factor (if using hybrid differencing) or use a lower order turbulence model. The first option is preferred as the latter options can have accuracy implications. ' It's from the FAQ of this forum.
August 12, 2012, 22:57 |
#9 |
Rep Power: 143 |
I wrote the FAQ so if it is unclear I would like to improve it.
My intention was to say that if the vortex is not important in the flow for the results you are interested in then you can dissipate out the vortex by coarsening that region of the mesh. But if this is an important part of the flow - for instance it adds resistance which significantly contributes to the over pressure drop in the simulation - then it is important and you should not get rid of it. So before you coarsen that region of mesh you have to make sure that it is not significantly contributing to important flow features. Only if it is not then you can coarsen the mesh in that area to get rid of it. |
August 13, 2012, 15:53 |
#10 |
Felipe Gobbi
Rep Power: 13 |
What is your problem message? What error does CFX-Solver point?
Display Modes | |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 07:41 |
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX | shiyun | ANSYS Meshing & Geometry | 4 | May 9, 2012 20:55 |
A question on adaptive remeshing or mesh deformation for handling object motions | daveatstyacht | OpenFOAM | 10 | November 13, 2010 10:29 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
