CFX solver issue (e
Old   August 13, 2012, 07:28
Default CFX solver issue (e
Mathieu PORSIN
MPORSIN is on a distinguished road
Hi everyone,
I am supposed to run a simulation of the combustion of a methane-air mixture involving an hydrogen car tank. My problem is when I launch CFX Solver and click on "Start Run", I obtain the following error message shows up :
"The ANSYS CFX solver has terminated without writing a results file.Command on host jndpc2489 exited with return code 0."
The output file says I have not set initial value for velocity in my domain, which is not true (I set up a value of 35 cm/s...). Does anybody have an idea of where it could come from?
Thank you in advance.
Regards,
Mathieu
output.txt
MPORSIN is offline   Reply With Quote
Old   August 14, 2012, 01:36
mat_cfd is on a distinguished road
I got similar error which was due to licence problem. Date and time on pc where I was trying to run simulation was not matching with pc from where it was picking the licence. I didnt check output file but error message was exactly same. It got corrected by setting date correctly.
mat_cfd is offline   Reply With Quote
Old   August 14, 2012, 07:54
If you have set this up as a multiphase simulation you may have missed setting a velocity for a phase. If you cannot find the problem post your CCL on the forum.
Old   August 15, 2012, 06:08
Mathieu PORSIN
Hi guys,
I finally solved the problem myself : actually the software was requiring more precise
information in term of spatial coordinate for the velocity. I also had some licencing issues, but I solved it as well.
Thanks for your replies.
CFX solver doesn't start through Workbench oj.bulmer CFX 3 June 30, 2012 08:44
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX shiyun ANSYS Meshing & Geometry 4 May 9, 2012 19:55
viewing cfx post while working on cfx solver manager HMR CFX 5 March 9, 2011 22:33
[ICEM] trouble with mesh quality from ICEM in CFX Solver escher25 ANSYS Meshing & Geometry 0 February 28, 2011 07:38
CFX 5.7.1 PRE and solver won't start daniel CFX 1 January 20, 2006 10:09
