Help in FSI : termination due to maximum simulation time
Old   August 16, 2012, 02:13
Default Help in FSI : termination due to maximum simulation time
kqlee is on a distinguished road
Dear all,
Good day. I'm doing FSI simulation on pipe for duration of 20 seconds with time step of 0.01s. After 500 iterations (about 4s), it suddenly terminated with the information :
Termination and Interrupt Condition Summary
CFD Solver: Run duration reached
(Maximum simulation time)
Does there anyone know how to enlarge the maximum simulation time? or is it due other problems? I really need your help here as i already try my simulation for almost 5 months but still unable to generate output yet. Thank you.
kqlee is offline   Reply With Quote
Old   August 16, 2012, 02:28
Lance
Lance is on a distinguished road
Did you set Solver control/Elapsed wall clock time control/maximum run time ?
Lance is offline   Reply With Quote
Old   August 16, 2012, 02:41
Dear Lance,
No, i didn't set the maximum run time. Would it be help if i set it?
Old   August 16, 2012, 02:45
Lance
No, not at all. I was just thinking that you had specified a maximum run time and that caused your simulation to stop.
since it says "CFD Solver: Run duration reached" my second guess would be that you have max iterations = 500 under analysis type/transient?
Old   August 16, 2012, 02:51
Dear Lance,
No, under Analysis type/Transient, i set 20s for the total time of coupling time duration, and 0.01s for the coupling time steps. but the simulation stop before completing the calculation (stop after calculating for 4s only).
Old   August 16, 2012, 03:14
I'm so sorry i check the wrong message, it terminated not due to the time step, but error occurred. Sorry for torubling everyone here.
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Time step for unsteady simulation Mohankumarg12 FLUENT 3 July 4, 2011 15:03
simulation not completed in HPDC (thin wall casting) flyingming FLOW-3D 3 January 20, 2010 11:24
Can Fluent start a simulation from a negative time Ted Chu FLUENT 10 November 26, 2008 21:06
