August 20, 2012, 10:16 |
pressure gradient plots
Shashwat
Rep Power: 14 |
Dear friend
I am doing blood flow through stenosed artery. I did transient analysis on this model. I am interested to plot pressure gradient from inlet to outlet. . I have calculated and constructed a time vs pressure plot at various points. But I need to know how to plot pressure gradient along the entire length. Thank you Regards Shashwat |
August 20, 2012, 10:34 |
Felipe Gobbi
Rep Power: 14 |
Hello there,
Try plotting "Pressure vs. Lenght (the same axis of the artery)". Good luck |
August 20, 2012, 13:10 |
#3 | |
Shashwat
Rep Power: 14 |
Please clarify the following: 1. Is it pressure gradient vs length or pressure Vs length? Note: I tried pressure gradient Vs length 2. Is the pressure gradient equal to average pressure /unit length measured in transient state? As I have already mentioned, I measured transient pressure values at various points on the axis then I calculated pressure gradient as (P1- P2)/l. This values are some what not matched with what you have suggested. Thanks Regards Shashwat |
August 20, 2012, 17:43 |
Felipe Gobbi
Rep Power: 14 |
What I suggested is simple, you would see how pressure changes with the lenght, and then I believe you'd have enough information for your case!
But I don't know if it's the same thing that you want I just try to give different solutions for one problem, see if it works, if it doesn't discard it... besides more ppl will answer you soon. Good luck! |
August 20, 2012, 19:13 |
Rep Power: 143 |
Isn't this a simple matter of defining a line object along the centreline of your geometry (or close to it) and plotting pressure along that line?
August 20, 2012, 21:01 |
Pressure gradient
#6 | |
Shashwat
Rep Power: 14 |
I could not understand your point. can you please give suggestions to calculate pressure gradient along the entire length? I did like this: I draw a line along the axis of the model then I fix the x axis as axial length and y axis as pressure gradient. Is this correct? |
August 20, 2012, 23:23 |
pressure gradient
Shashwat
Rep Power: 14 |
Dear friend
I would like to take average pressure gradient along the axis . I found that If I simply put the line along the axis and export the pressure is wrong. because that pressure is same as the end of the transient simulations. kindly give any method to get average pressure over the time period vs axial length and pressure gradient(over the time period) vs axial length thanks regards shashwat Last edited by shaswat; August 21, 2012 at 00:10. |
August 21, 2012, 19:33 |
Rep Power: 143 |
Put some monitor points along the line and redo the simulation. Export the data to matlab/excel/whatever and calculate your averages and gradients.
August 23, 2012, 04:45 |
#9 | |
Shashwat
Rep Power: 14 |
I have already put some monitor points during simulations. But I need to know how to export the data at the monitor points in cfx post Thank you Regards Shashwat |
August 23, 2012, 05:31 |
#10 |
Rep Power: 13 |
Hi
maybe this could be another solution/help: have u tried creating an additional Variable"PaGrad"(Type unspecified/ Unit e.g. [Pa m^-1]/Tensor Type Vector), specify it in your fluid-domain as Vector Alg. Eq. with the Values "Pessure.Gradient X" ... and do e.g. a volume rendering plot in cfx-post? ok the volume rendering arent the most useful plots but very nice to look at |
August 23, 2012, 08:03 |
#11 |
Rep Power: 143 |
You can export monitor point data in the solver manager.
August 23, 2012, 10:53 |
#12 | |
Shashwat
Rep Power: 14 |
can you explain further please. creating additional variable in cfx post? thanks |
August 23, 2012, 10:55 |
#13 |
Shashwat
Rep Power: 14 |
August 23, 2012, 13:55 |
#14 |
Shashwat
Rep Power: 14 |
dear friends
I got a transient results from monitor points. but I didn't get my pressure values when t=0 ( Cfx solver manager) When I use CFX post I got the above result when t=0 too Please clarify thanks Govind |
August 24, 2012, 00:33 |
pressure gradient
#15 |
Shashwat
Rep Power: 14 |
Dear friends
I just recall pressure gradient which is equal to (P1-P2)/L = constant I got average pressure by inserting monitor points. I need to calculate pressure gradient [( P1average- P2 average)/l] Is it correct? After completing transient analysis, How to calculate pressure gradient between 100 over points along the axis of the flow. It is tedious process to put 100 over monitor points along the axis and find the average pressure at all the points then finding pressure gradient [(p1average-P2average )/l] Is there any way to calculate ? Thanks Shashwat |
August 24, 2012, 04:12 |
#16 | |
Rep Power: 13 |
creating the additional variable: cfx-pre afterwards u can also use this variable for monitor points ... p.s. i missspelled s.th. -> "Pressure.Gradient X" - the other values are Pressure.Gradient Y ... |
August 24, 2012, 07:41 |
#17 |
Rep Power: 143 |
You can set up lots of monitor points a few ways:
* export your CCL with one monitor point set up. copy/paste the CCL for the monitor point and edit it to include all the points. Import it back into CFX-Pre or the solver. * Use perl in the CCL to generate the monitor points. |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 10:34 |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
Pressure BC for combustion chamber | Giuki | FLUENT | 1 | July 19, 2011 11:35 |
How to create an inlet with pressure gradient? | val17lr | FLUENT | 5 | July 13, 2010 15:15 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
