Ramping Boundary Condition for Steady FSI Simulation
Old   August 20, 2012, 23:32
Question Ramping Boundary Condition for Steady FSI Simulation
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Dear all,
I am doing steady FSI modelling in an artery model.
I know how to ramp the pressure boundary condition for transient FSI case; however, I don't know how to ramp the pressure boundary condition for steady FSI.
In transient modelling, because the pressure is dependent on time, so the time can be used as an independent variable to ramp the boundary condition like below
P=12*10*t*step((0.1-t))+12*step((t-0.1))
Although for steady flow there is not any independent variable to be used for ramping.
I would be too pleased if any could help me.
Regards,
AshtonJ
ashtonJ is offline   Reply With Quote
Old   August 21, 2012, 03:25
Lance
Lance is on a distinguished road
Do a transient simulation first and use the results as input for your steady simulation?
Lance is offline   Reply With Quote
Old   August 21, 2012, 04:13
Ashkan Javadzadegan
Thank you. To be honest, I cannot understand what you mean!
Just letting you know that first I need to run steady case then use the steady case results as the initial condition for transient case. I’ve had difficulty in converging the steady case with applied boundary condition, so I am trying to ramp the boundary condition to see if it helps.
Regards,
AshtonJ
Old   August 21, 2012, 04:18
Lance
I see. I thought you wanted to do a steady FSI.
If you are going to ramp up your BCs you need to to a transient analysis to reach a steady-state from where you can continue with your "real" BCs. Then just use the last results from the ramping transient analysis as initial condition.
Boundary condition setting regarding turbine simulation using CFX Lacerlacer CFX 11 March 12, 2012 10:32
Transient Simulation: Boundary Condition Problem Shafiul CFX 7 January 11, 2011 17:40
Best Boundary condition for FSI mbn1454 STAR-CCM+ 0 December 4, 2010 05:26
Boundary condition, UDF, Wave simulation hm FLUENT 0 August 2, 2004 22:45
2D simulation as boundary condition for 3D problem Jan De smet FLUENT 1 October 11, 2002 03:02
