-   -   User Fortran problem: The name 'UserSource2' is ambiguous ? (http://www.cfd-online.com/Forums/cfx/106270-user-fortran-problem-name-usersource2-ambiguous.html)
yuhai August 23, 2012 11:18
Dear CFXer,
I am solving a case with User Fortran, the source is similar like in the Tutorial: 17.7.2.2 User Fortran Routine, so I modified this tutorial code for my case.
On linux platform, I can successfully compile, and get AdVarSource.o and libAdVarSource.so.
but when I start simulation, I got the following error:
Error processing expression 'Source'.
The name 'UserSource2' is ambiguous - it is a both a system variable and the name of an expression.
The variable name 'UserSource2' is not recognised.
The following unrecognised name was referenced: UserSource2.
Error processing expression: Source = UserSource2
Can you give some hints on this?
(Now, I have actually no Expression defined.)
Thank you very much.
H.Y.
