May 28, 2010, 02:32 |
CFX Streamline Curvature Correction model
CFX 12.0 has got a streamline curvature correction model. Also, it provides few parameteric tuning into it, such as CSCALE. When to use this model ? and what shall be the range of values for CSALE ? Would be greatfull if someone tells about why its to be used ..
May 28, 2010, 07:47 |
Rep Power: 143 |
It is to correct turbulence generation in strongly swirling flows. Don't fiddle with the constants unless you REALLY know what you are doing, and certainly not before reading the literature about what the constants mean.
May 28, 2010, 07:52 |
Thanks Glenn for the reply. Exactly the same flow i am trying to simulate which has strong swirls in it. However, the solution shows intense variation as I change the parameter CSCALE value over small ranges ....
May 28, 2010, 07:59 |
even in smaller range of values for CSCALE, such as, 1, 1.5 and 2.0, the solution varies immensly. The CFX Solver theory guide do not talk about any guidance on it. They do not suggest any range for it. For how much intense swirl flow what value of cscale one shall belive on ? no idea. Secondly, if the sreamline curvature correction model does take care of the curvature effect due to swirl flow then why shall we need the cscale ?
May 28, 2010, 08:07 |
#5 | |
Rep Power: 143 |
Whether you need the curvature correction model or not is up to you. Run with it and without it and see if it makes a difference to your models. Also keep in mind that other turbulence models may be more appropriate such as RSM or LES. 2-equation turbulence models are well known to have problems with strongly swirling flows. |
May 28, 2010, 08:59 |
yes Glenn, i googled through the CFX document for streamline curvature correction model, which pointed to Literature article by Spalart & Shur.
I checked with the article as well, surprisingly, the original model as in the article does not talk about any scaling factor as such. |
May 29, 2010, 07:10 |
Rep Power: 143 |
You would have to talk to CFX support for more detailed information about this model then.
August 29, 2012, 15:44 |
Hesam Moghaddam
Rep Power: 14 |
I am simulating blood flow in an artery and my streamlines doesn't start from inlet and their shape is swirling instead of straight through the artery (pipe). do u have any idea what the problem can be?
I have attached the pic thanks, |
August 29, 2012, 18:32 |
#9 |
Rep Power: 143 |
Your image is unreadable.
But the problem is going to be in your setup, or it is not fully converged. Please do not hijack threads. For a new question start a new thread. |
CFX Liquid Evaporation Model | Jinx | CFX | 3 | January 28, 2010 16:31 |
Import Fan 3D Model - Workbench or CFX? | Stewart Long | CFX | 2 | October 28, 2008 04:05 |
How to use the competing reaction model in CFX 11 | NewCoalman | CFX | 0 | May 5, 2008 03:15 |
where to set CFX Transition Model? | steven | CFX | 6 | January 17, 2007 11:19 |
Use of 1 equation turbulence model in CFX 4.3 | Niels Deen | CFX | 0 | July 19, 2000 08:50 |
