September 2, 2012, 16:29 |
Need .msh file in new CFX-Pre file
Rep Power: 16 |
Hi I have a question may it seems strange something I have a CFX-Pre file I want to regenerate .msh file from it because I delete my MESH file by mistake I want to use it in new CFX-Pre file with settings differ from the first one is that possible?
September 2, 2012, 19:06 |
Rep Power: 143 |
You can just import the def file (or whatever file format you have) in CFX-Pre and I think it comes in just like a .msh file.
September 3, 2012, 09:27 |
Rep Power: 16 |
Hi Glen I open CFX-Pre and go to the menu file>import>mesh when I selecting the .def file the following error appeared:
ERROR There is a problem importing mesh from the requested file the importing process reported the following problem: Unable to import mesh: No 3D elements imported ??????? what the problem? Mariam |
September 3, 2012, 18:35 |
Rep Power: 143 |
Is it a valid .def file? It does not look like it.
September 4, 2012, 03:12 |
Rep Power: 16 |
I succeeded at last I did mistake before with the type of file imported I select type as all types (*) hence the file not imported correctly when I select the type as CFX solver Input (.def) I get it correctly thanks a lot. I just want to ask with the mesh file imported now I get completely default case settings differ from the previous one?
September 4, 2012, 18:42 |
Rep Power: 143 |
I think so, but am not sure. Best you check this yourself if it is important for you.
Display Modes | |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 04:26 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
