I can't plot a velocity distribution
Old   August 30, 2012, 17:18
Default I can't plot a velocity distribution
Stabum's Avatar
Stabum is on a distinguished road
Hello. I'm sorry if i don't speak english very well, but I'll try my best to make you understand my problem.
I need to plot the distribution of the circumferential velocity all the way around the outlet border of this nozzle (not exactly at the wall, just a little bit far from the nozzle wall). I've created a polyline using the "file" option (inside this file I stored the coordinates of 60 points through which the polyline passes) -maybe you can see it painted in green- and now I have to plot this velocity component vs the variable "Gamma Var" defined as follows:
Expressions -> New Expression -> Gamma Expr -> atan(y/x)
Variables -> New Variable -> Gamma Var -> Details of Gamma Var -> Expression -> Gamma Expr.
Then I've created a new Chart, I've selected a new data serie indicating the polyline already created. Then in the X tab I've selected "Gamma Var" as my X variable and "Velocity Circumeferential" as my Y variable.
Nothing happens apart the warning: 'No data exists for variable "Gamma Var" specified in object "chart Line 1'.
Where do I committ my mistake??? Please please help me...
P.S: X axis is parallel but not coincident with the nozzle's symmetrical axis. The inlet and outlet planes are parallel to YZ planes
Stabum is offline   Reply With Quote
Old   September 3, 2012, 18:56
Erik
evcelica is on a distinguished road
I can't see the green line well, but is it inside your models bounds?
evcelica is offline   Reply With Quote
Old   September 4, 2012, 21:51
Erik
looking again you have atan(y/x), should this be (y/z?)
Time-averaged velocity plot for a transient simulation mali28 FLUENT 21 September 24, 2019 22:34
how to apply circumferential velocity distribution pks126 Main CFD Forum 0 August 20, 2012 13:00
velocity profile plot girishg Main CFD Forum 0 February 24, 2011 18:11
how to plot RMS velocity (fluctuating velocity) nash Main CFD Forum 0 October 18, 2006 16:37
