surface tension model
These days I do a multi-phase simulation using free surface model and homogeneous model.
At first i do not turn on the surface tension model, it converges badly,and it converges good when i take the surface tension model into consideration. In my simulation,the water and gas interface is well0defined. I am confused why the surface tension force has such a significant role in this simulation. |
Usually the surface tension makes convergence harder, so your application is unusual.
Can you describe what you are modelling, what fluids and what geometry? |
I wonder why should we take the surface tension force into consideration. What will it influences? |
What type of injector? How big? Is it producing a spray of droplets or some other flow?
Pressure-swirl injector.Yes,it is intended to produce spray of droplets finally. |
Do you want to simulate the spray break up process directly, or use empirical models (eg LISA)?
I do not know the details of your model so cannot answer your original question.
However surface tension is critical to spray formation. The droplet formation process is driven by surface tension. So your comment about why you need surface tension is puzzling. |
1 Attachment(s)
Now ,i am doing the INTERNAL flow simulation,like a pipie, not the spray process.The process before spray in the injector. |
If this is an internal flow then isn't it single phase? Where does the gas/liquid mix come from?
1 Attachment(s)
It is a pressure-swirl injector, SWIRL means the liquid phase has a tangential velocity after it flows through swirl part (as the picture attached)of the injector. According to the fluid mechanics,the fluid will have low static pressure having tangential velocity. So, in my case, the pressure of the liquid at the exit is lower than the atmospheric air,causing the air flow in the injector,and that helps the atomization process The the mechanism of the pressure-swirl injector. |
I wish am clear enough.
Thank you again. |
I see. It is hard to know whether surface tension will be important in this or not. If you are close to the injector and before the surface tension has started to form the wobbles which grow and break the sheet up then you might not need it.
So if unsure then I would include it. Be aware that surface tension models require very good mesh quality and much smaller time steps. |
Thanks sincerely.
CFD is not easy. |
No, it is not easy. That is why it is interesting.
Yes.
But,sometimes it drive me crazy when i can not figure it out. Sometimes a small change will lead to much difference and i can not understand it. |
