-   -   Error while opening cfx file in cfx pre (http://www.cfd-online.com/Forums/cfx/106721-error-while-opening-cfx-file-cfx-pre.html)
pks126 September 6, 2012 07:15
p, li { white-space: pre-wrap; } ERROR
The supplied secondary file name, /root/.cfx/CFX_TEMP_19606//temp.00.gtm, can not
be opened as a lock file, /root/.cfx/CFX_TEMP_19606//temp.00.gtm.lck,
exists.
If this is the result of a previous failed run then try deleting the
lock file and repeating the operation.
There was a problem copying the GTM database from
/home1/Prasanth/distortion_screen _correct mesh0.cfx
to
plz suggest some solution!!!
evcelica September 6, 2012 08:39
pks126 September 6, 2012 08:52
dear evcelica
i tried same but its not working
evcelica September 6, 2012 11:01
do you have workbench? if you open the project in workbench it will inform you of the lock and you can delete it from there.
pks126 September 7, 2012 03:22
thanks evcelica
i deleted all the files including lock files which are of no use .........now its working and no error like that showing :)
evcelica September 7, 2012 13:19
I hate those stupid lock files, so annoying!
