how to consider buoyancy without switching heat transfer on
Old   November 26, 2012, 14:41
Default how to consider buoyancy without switching heat transfer on
tsh850227 is on a distinguished road
Hi, I am a beginner of cfx. In my simulation, I want to consider buoyancy, but heat transfer. In default setting of buoyancy, the Buoy. Ref. Temp. option cannot left blank. If I specify a temperature here, the simulation type will be switched to heat transfer. Is there anybody can show me how to fit this problem? sorry for that my english is quite poor.
Thanks in advance
tsh850227 is offline   Reply With Quote
Old   November 26, 2012, 16:27
What is driving the buoyancy in your simulation? Is it temperature gradients, multiphase or multicomponent?
Old   November 27, 2012, 05:13
it is independent of temperature, i just want to model the motion of a rigid ball in a container, so i need to consider the buoyancy. thanks ¬¬¬
Old   November 27, 2012, 05:22
I see. Can the bouyancy of the rigid body be represented by an external force? Then you do not need to use the buoyancy model in CFX and can turn all that stuff off.
Old   November 27, 2012, 05:25
thanks for your guidance, i will have a try¬¬¬many many thanks¬¬
Old   November 27, 2012, 11:52
anonymous
Doginal is on a distinguished road
Please correct me if i'm wrong. But my understanding is that it does not turn on heat transfer. The buoyancy reference temperature is used to get a density difference based off a difference in temperature.
i.e.
If you have a domain filled with water at 25 C and you apply a reference temperature of 0 C then it would act to create a force on your full domain based off the difference in density of water at 25 C and water at 0 C. It does not apply a heat transfer.
In your case, if you only have 1 phase and it fills a container setting the buoyancy ref temperature to the same reference temperature of your fluid (typically default is 25 for both air and water) should be fine and you will be able to apply your gravity force.
*note: you can check the reference temperature of the fluid your working with by opening the materials tree menu and clicking on your material. Its a material property of the fluid
Doginal is offline   Reply With Quote
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Heat Transfer mechanisms tafaugl CFX 1 November 7, 2012 18:46
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
