Home > Forums > CFX
Problem with negative velocity values
Old   September 19, 2012, 18:29
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
This is very confusing.
Sorry, a small tangent there
Are you displaying all the points? In solver manager, right click on the monitor point graph and select Monitor Properties, then Range Settings. Under Timestep Range Mode you can select whether it shows all points or only a subset.
Old   September 20, 2012, 05:02
Andris is on a distinguished road
Yep, I go to monitor properties, set 'range settings' to 'display all', put 'plot data' by 'simulation time', the run is for 5 seconds at a time step of 0.01. Yet for every simulation, it stops plotting the monitor points even though the run keeps on going. I exported the results to excel to see if perhaps I could access them there but still no luck.
Andris is offline   Reply With Quote
Old   September 20, 2012, 07:34
Something weird is happening with your simulation. I have used this feature many times and it works just fine for any length simulation.
Does the simulation continue otherwise OK? That is, the output file is still being written, the residuals are still coming up on the solver manager and when you stop the run the results file is written?
Old   September 20, 2012, 08:52
Yep, the run still keeps on going, a results file is written, all the residual values can still be seen. Everything works perfectly except that the monitor points just don't plot. They reach a certain time and stop, even though the simulation is running iterations for time steps way past those shown in the monitor graphs.
Thread Tools
Trackbacks are On
[ICEM] negative mesh volume problem (icem-cfd/cfx) adam2008 ANSYS Meshing & Geometry 5 April 16, 2010 12:21
Plot a graph of velocity & boundary condition problem wanie Fluent UDF and Scheme Programming 0 December 11, 2009 11:40
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 05:36
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
