How to get Pro/E Parameters to Show Up
Old   February 7, 2012, 12:54
Default How to get Pro/E Parameters to Show Up
Dustin
Trues is on a distinguished road
I've used the Pro/E - CFX associativity before, with static structural analysis, to use Pro/E parameters in ANSYS WB for a tabulated solution.
However, I can't get the parameters to work when doing a Fluid Flow (CFX) analysis.
Here's what I have:
- The proper Pro/E plugin for ANSYS WB 13
- The geometry created in Pro/E, open in the background
- Parameters set in Pro/E with a "DS" infront of each parameter name
- The geometry imported into a Fluid Flow (CFX) project
- The geometry meshed
- The setup created
Here's what I don't have:
I checked the Geometry properties in ANSYS. 'Parameters' is checked, and Parameter Key is correctly set to "DS".
How do I get that parameters block to show up?!
Thanks,
Trues is offline   Reply With Quote
Old   February 7, 2012, 13:09
Dustin
WOW! This is so typical of me. I've been working on this for a day now. I posted this a few minutes ago, and I already figured it out, ha .
But, to not waste forum space, let me know if anyone is interested or is having the same problem.
Old   September 14, 2012, 11:26
Default I want to learn how to set up parameter. Thanks a lot
MichaelCFD is on a distinguished road
How to set up parameter in Pro/E? How to use in Ansys? I greatly appreciate it if you can help me out here. Thank you.
MichaelCFD is offline   Reply With Quote
Old   September 14, 2012, 13:11
Dustin
Michael,
I'm willing to help, but could you help me a bit with your question? Do you have the ANSYS-Pro/E link setup? (Does ANSYS recognize Pro/E geometry?)
If so, I can go into more detail
Old   September 17, 2012, 20:26
Dustin
I answered this question in a new post. See the guide at the link, here:
http://www.cfd-online.com/Forums/ans...ion-guide.html
Thanks!
proe parameter
Parameters for multigrid solver HaZe OpenFOAM Running, Solving & CFD 3 January 28, 2012 02:05
twoPhaseEulerFoam - parameters grjmell OpenFOAM 1 June 16, 2011 08:13
units of geometrical parameters lost SoobY ANSYS Meshing & Geometry 2 January 10, 2011 03:58
New to CFX-need explanations about mesh parameters Cyril CFX 3 November 24, 2006 06:33
pro/e to gambit Ana Raquel Rosado FLUENT 1 October 12, 2006 07:46
