Problem at interface: an object is present but it is not physically valid
Hello dears,
I'm doing a simulation with a part made of a porous domain with a solid phase and a fluid phase (resin), with an additional variable defined only inside the resin ("alfa", additional variable defined through a transport equation). The porous domain flows in a steel die: with this configuration all works fine. When I insert in the porous domain also a second fluid (air ideal gas), I have a warning that say me: "The object "ADDITIONAL VARIABLE: alfa" is present in the object "/FLOW:Flow Analysis 1/DOMAIN:Part/BOUNDARY: Default Solid Porous Interface Side 1/BOUNDARY CONDITIONS" but it is not physically valid. Substantially I have a problem at the die-part interface (at porous domain side). Opening the specified interface window, it isn't possible to delete alfa from the interface. How I can do? |
Hello, anyone can help me?
Thanks |
I am not sure but I suspect you have to define your AV in all domains. I do not think it can only exist in one domain.
So I don't think it is a problem of domains, I think that could be a multiphase problem, because it only presents when I introduce the air... |
| All times are GMT -4. The time now is 06:29. |
