FSI Mechnical Contact Problem in Labyrinth Seal Calculations
Old   September 18, 2012, 15:59
Default FSI Mechnical Contact Problem in Labyrinth Seal Calculations
peterputer is on a distinguished road
Hej,
i m running a FSI calculation in labyrinth seals. Problem is that the distance between stator and labyrinth seal top is pretty small so that a contact is placed automatically by Ansys Mechanical, connecting Rotor and Stator at that point. At least thats my guess what that Notification is trying to tell me:
There is no auto contacting, does anyone know how i can set this off? In mechanical i just deleted the contact but it seems to be replaced after starting the calculation.
Any help is appreciated
Regards Peter
*** NOTE *** CP = 7.844 TIME= 21:46:35
It is highly recommended to use the auto contact setting option by
issuing CNCHECK,AUTO command for this problem in order to achieve
better convergence.
Force-distributed-surface identified by real constant set 3 and
contact element type 3 has been set up. The pilot node 72492 is used
to apply the force which connects to other element 15239. Internal
MPC will be built.
The used degrees of freedom set is UX UY UZ ROTX ROTY ROTZ
Force-distributed-surface identified by real constant set 5 and
contact element type 5 has been set up. The pilot node 72493 is used
to apply the force which connects to other element 15240. Internal
MPC will be built.
peterputer is offline   Reply With Quote
seek help:a problem about FSI caosheng ANSYS 11 November 21, 2017 13:21
Problem when created 3D FSI for ADINA software. mr_iskandarothman Main CFD Forum 0 March 2, 2012 14:29
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
Looking for a open FEM code to solve a FSI problem Esto Main CFD Forum 3 June 15, 2006 11:02
Valve seal problem! Urgent songxguan Main CFD Forum 0 May 11, 2006 22:04
