September 21, 2012, 12:07 |
Cylindrical Symmetry
Vikram Reddy
Hello CFX users, I have a reactor with cylindrical symmetry. How do I solve the problem on only one plane of theta?. I know this is to be done using slice material but when I slice an arc that does not form from the center of the cylinder.
Please help. |
September 21, 2012, 12:30 |
Dustin
what program was used to make the geometry? Do you have the ability to modify that geometry, or was it given to you?
For me, if it was given to me as a full cylinder (for example) in ProE, I'd much rather make the cyclic cut in ProE than in DesignModeler |
September 21, 2012, 12:52 |
Vikram Reddy
Thanks for the reply.
I made the geometry myself in DesignModeler |
September 21, 2012, 14:48 |
Dustin
A picture would speak 1000 words.
If I'm picturing your issue correctly, which it's possible I'm not, you're having trouble getting the slice to go through the centerline of the cylinder? Why don't you add a new coordinate system at the centerline on the face of your cylindrical geometry and sketch your slice so that you can constrain it to the geometry centerline? |
September 21, 2012, 14:52 |
Vikram Reddy
In the sliced material, when I give the inward thickness on extrude to be less than 2 cm( which is the radius of the cylinder), it accepts. But when I want it to be 2cm it wont accept the value. Does it make more sense now?
September 21, 2012, 14:56 |
Dustin
sounds like you're trying to slice a wedge out of your cylinder, right? Your sketch needs to be opened. Don't draw the arc, just the two radials, like an open V. Is this what you're having trouble with?
September 21, 2012, 15:00 |
Vikram Reddy
Yeah, you figured it out right but,
I could draw the outer edge but not the one closer to the center i.e, i can not draw the sharp edge. |
September 21, 2012, 15:11 |
Dustin
The only other thing i can say is try with thin surface set as no. I'd have to see what you're talking about to help any further
September 21, 2012, 20:44 |
Erik
Rep Power: 23 |
Dont slice or cut your geometry. Just use TOOLS > SYMMETRY. Set to two planes, have one plane be whatever plane cuts through the center, and create another plane rotated 1 degrees or so off that one.
September 24, 2012, 21:12 |
Vikram Reddy
Thank you very much, I used symmetry and it worked perfectly.
September 25, 2012, 04:43 |
#11 |
Erik
Rep Power: 23 |
No problem. Yeah, the symmetry tool works very well for symmetry
September 25, 2012, 07:50 |
#12 |
Bruno
Rep Power: 21 |
Also, remember to set periodicity in ANSYS Meshing so that you get a 1:1 mesh connection when setting your periodic BCs in CFX. GGI interfaces do work pretty well, but by using a 1:1 interface you save memory and CPU time.
Cheers |
September 25, 2012, 09:03 |
#13 |
Rep Power: 143 |
If the simulation has no swirl then use symmetry planes on the top and bottom faces. If the simulation has swirl then use periodic boundaries.
BTW: This thread is an FAQ - http://www.cfd-online.com/Wiki/Ansys..._simulation.3F You might as well just point people to the FAQ. If you think the FAQ is wrong or could be improved then feel free to edit it. |
View factor radiation model. Symmetry boundaries verification.. | Dimoon | OpenFOAM Running, Solving & CFD | 12 | April 6, 2021 04:38 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 04:13 |
stressedFoam with wall motion looses symmetry and does not converge | gtg258f | OpenFOAM | 1 | June 6, 2012 13:28 |
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! | Cirion0000 | CFX | 0 | July 6, 2009 15:26 |
Forces in Symmetry | Matt | CFX | 2 | February 25, 2009 06:41 |
