Question about CFX-pre and CFX-post script
May I ask do CFX-pre and CFX-post have script to record all my setting so that after I import the mesh(or .res file) I won't need to set them again and by running the script I obtain the setting(or picture) directly? |
Yes, they have the abilities you mentioned. In the CFX-Pre you can import and export CCL files. In the CFD-post you can save and reuse a state file (.cst file)
Pre and Post also have session files which are like recording and playing back user actions.
file=>export=>CCL and in your next simulation file=>import=>CCL
For example, if the number of domains varies, your CCL will define the first X domains but not all of them. (the same with interfaces, boundaries, etc) Otherwise, this method works very well in CFX-pre and CFX-post. |
Thanks! |
A .cfx format file is a session file. You can use it to do your work!
Scripting single node in CFX
Can I ask you about CFX-post scripting. Is it possible to read ex. temperature from a single node? Have you ever tried to define the parameters to the single node in CFX -pre? may you have same examples? Thanks Adrian |
AC |
best regards Adrian |
In CFX-Post I can do this with session file (.cse) In CFX-Pre I can use CCL. If I am wrong please let me know. I thought I can select nodes/points from the 'wall boundary condition' and write to file values from this nodes/points. I can write to file (Perl+csv) but how Can I get a value from the nodes/points from the 'wall boundary condition'? Adrian |
