Cylindrical Symmetry
Old   September 21, 2012, 11:07
Default Cylindrical Symmetry
Vikram Reddy
VikramR is on a distinguished road
Hello CFX users, I have a reactor with cylindrical symmetry. How do I solve the problem on only one plane of theta?. I know this is to be done using slice material but when I slice an arc that does not form from the center of the cylinder.
Please help.
VikramR is offline   Reply With Quote
Old   September 21, 2012, 11:30
Dustin
Trues is on a distinguished road
what program was used to make the geometry? Do you have the ability to modify that geometry, or was it given to you?
For me, if it was given to me as a full cylinder (for example) in ProE, I'd much rather make the cyclic cut in ProE than in DesignModeler
Trues is offline   Reply With Quote
Old   September 21, 2012, 11:52
Vikram Reddy
Thanks for the reply.
I made the geometry myself in DesignModeler
Old   September 21, 2012, 13:48
Dustin
A picture would speak 1000 words.
If I'm picturing your issue correctly, which it's possible I'm not, you're having trouble getting the slice to go through the centerline of the cylinder? Why don't you add a new coordinate system at the centerline on the face of your cylindrical geometry and sketch your slice so that you can constrain it to the geometry centerline?
Old   September 21, 2012, 13:52
Vikram Reddy
In the sliced material, when I give the inward thickness on extrude to be less than 2 cm( which is the radius of the cylinder), it accepts. But when I want it to be 2cm it wont accept the value. Does it make more sense now?
Old   September 21, 2012, 13:56
Dustin
sounds like you're trying to slice a wedge out of your cylinder, right? Your sketch needs to be opened. Don't draw the arc, just the two radials, like an open V. Is this what you're having trouble with?
Old   September 21, 2012, 14:00
Vikram Reddy
Yeah, you figured it out right but,
I could draw the outer edge but not the one closer to the center i.e, i can not draw the sharp edge.
Old   September 21, 2012, 14:11
Dustin
The only other thing i can say is try with thin surface set as no. I'd have to see what you're talking about to help any further
Old   September 21, 2012, 19:44
Erik
evcelica is on a distinguished road
Dont slice or cut your geometry. Just use TOOLS > SYMMETRY. Set to two planes, have one plane be whatever plane cuts through the center, and create another plane rotated 1 degrees or so off that one.
evcelica is offline   Reply With Quote
Old   September 24, 2012, 20:12
Vikram Reddy
Thank you very much, I used symmetry and it worked perfectly.
Old   September 25, 2012, 03:43
Erik
No problem. Yeah, the symmetry tool works very well for symmetry
Old   September 25, 2012, 06:50
Bruno
brunoc is on a distinguished road
Also, remember to set periodicity in ANSYS Meshing so that you get a 1:1 mesh connection when setting your periodic BCs in CFX. GGI interfaces do work pretty well, but by using a 1:1 interface you save memory and CPU time.
Cheers
brunoc is offline   Reply With Quote
Old   September 25, 2012, 08:03
If the simulation has no swirl then use symmetry planes on the top and bottom faces. If the simulation has swirl then use periodic boundaries.
BTW: This thread is an FAQ - http://www.cfd-online.com/Wiki/Ansys..._simulation.3F
You might as well just point people to the FAQ. If you think the FAQ is wrong or could be improved then feel free to edit it.
View factor radiation model. Symmetry boundaries verification.. Dimoon OpenFOAM Running, Solving & CFD 12 April 6, 2021 03:38
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 03:13
stressedFoam with wall motion looses symmetry and does not converge gtg258f OpenFOAM 1 June 6, 2012 12:28
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 14:26
Forces in Symmetry Matt CFX 2 February 25, 2009 05:41
