How to find coefficient of power and coefficient of torque with CFD in turbine ? |
April 23, 2022, 11:44 |
Vimal Chaudhari
Rep Power: 3 |
I am working on the performance of Savonius turbine using Ansys CFX. Turbine domain motion is Rotating in CFX. I am getting trouble in the equation of Coefficient of Power and Coefficient of Torque in CFX. Guide me to find force, torque, Coefficient of Power and Coefficient of Torque in the form of equation in the form of CEL.
April 24, 2022, 00:03 |
Rep Power: 143 |
You can get the torque on the device by simply taking all the surfaces which make up the rotating surface and using the CEL expression torque()@Surface Name. You can also specify which axis to take the torque around with torque_x, torque_y and torque_z. Likewise the force just uses the force and force_x/y/z functions.
You can also use the calculator in CFD-Post to calculate these functions in post-processing. From the torque and force you can evaluate the functions for the other parameters depending on how you have defined them.
April 24, 2022, 08:14 |
Vimal Chaudhari
Rep Power: 3 |
Thanks for reply Glenn sir,
I am working on Savonius turbine which has 'S' shape two blades (At a 0 degree angle of rotation one blade has Concave shape and another has Convex shape) which are mounted on a central shaft. Turbine domain motion is Rotating in CFX. So CEL expression 'torque_z()@SurfaceName' is appropriate to find torque produce by turbine ? |
April 24, 2022, 21:21 |
Rep Power: 143 |
As long as the rotation axis is the global Z axis and you have defined all the rotor surfaces as an object named "SurfaceName" - then yes it should work.
Display Modes | |
How to average the torque coefficient for vertical axis wind turbine? | NotOverUnderated | FLUENT | 2 | September 6, 2022 15:55 |
Calculating the Cp (Power Coefficient ) for a cross flow vertical wind turbine | AS_Aero | CFX | 13 | February 14, 2018 17:57 |
Wrong power coefficient prediction in CFX for hydrokinetic turbine | Iggy | CFX | 6 | August 1, 2015 03:56 |
power coefficient Horizontal Axis wind turbine in fluent | Ansys2015 | FLUENT | 0 | June 26, 2015 05:14 |
Need help on calculation of power coefficient for contra-rotating turbine | altomos | CFX | 5 | October 7, 2012 07:26 |
