it doesn't have "topology estimate factor zif"
Hi
cfx 12.1 gives this error for my simulation: ERROR #001100279 has occurred in subroutine ErrAction. Message: SYMASS_ZIFCS_EL: The solver ran out of temporary space while building a linked list for a domain interface. Try setting the expert parameter "topology estimate factor zif" to a value greater than 1.0. Values higher than 1.2 should not be necessary. but in expert parameter it doesnt have "topology estimate factor zif" option!! it just has "topology estimate factor" what should I do with this error? I found this option in cfx 13 but not in cfx 12.1 thanks |
normally, you should find it here:
=> simulation/flow analysis/solver/insert/expert... it would surprise me, if v.12 doesn't have this paramter |
I'm surprised too!
I searched it in expert parameter---->convergence it has "topology estimate factor" but not "topology estimate factor zif" I'm really confused I've checked it 10 times!! I couldn't find it even in cfx 12.1 help. I know that this option is on cfx 13.can anybody check it on cfx 12.1 please? thanks |
I know what is this error for I just can't find the option
can anybody help me to find it please? maybe my cfx doesn't have it can you check it please |
Go in the command editor foor Expert Parameters and just type it in as the instructions say. CFX will accept it.
See the solution here: http://www.eureka.im/4310.html |
hi
I have the error massage same to above. I used ANSYS v13 want to change topology estimate factor zif . Or how to eliminate this massage |
| All times are GMT -4. The time now is 08:49. |
