-   -   solver stop problem in Lagrangian Particle Tracking (http://www.cfd-online.com/Forums/cfx/107698-solver-stop-problem-lagrangian-particle-tracking.html)
sakurabogoda October 4, 2012 07:20
Dear All,
I am using CFX 12 to model multiphase flow. My problem is when I used Eulerian-Eulerian multiphase model solver runs well but when used Lagrangian Particle Tracking it stopped with following error.
Host computer: AMD2
Job started: Wed Oct 03 18:05:58 2012
Unable to check out 1 licenses: No license for ANSYS CFX Solver (All Models) co
uld be found.
| ERROR #001100247 has occurred in subroutine . |
| Message: |
| The solver is unable to continue because of licensing problems. |
| A license for the following capability level could not be checked |
| out: |
| Full Capability Solver |
| Please carefully examine the error message output above and check |
| that: |
| 1) The license server is specified correctly and is running. |
| 2) An appropriate license is available for checking out. |
| These problems can be checked using the ANSYS Client ANSLIC_ADMIN |
| utility. For further troubleshooting information please consult |
| ANSYS, Inc. Licensing Guide. |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
This run of the ANSYS CFX Solver has finished.
I wonder that why this happens only I used Lagrangian Particle Tracking.
Please help me. I am going crazy with this.:(
ghorrocks October 4, 2012 07:37
Particle tracking requires a multiphase license option or a Full capabilities license option. If you only have the basic CFX license you will not have this, so cannot do any multiphase modelling.
sakurabogoda October 4, 2012 22:43
Dear Glenn, thanks for the reply.
If I can do Eulerian-Eulerian multiphase model, then the license is Full capable. Isn't it?
When I used Air= Continuous Phase; Dust=Dispersed Phase. Then it worked.
When I changed Dust=Particle transport solid it stopped due to above error.
There is no error or mistake that I can find.
ghorrocks October 5, 2012 06:09
It might be the particle tracking uses a separate license. I do not know the details of CFX licensing (and they change it every release anyway), so you would have to contatc CFX support.
