Radiation interface
as I can model radiation in semitransparent material, in the domain Interfaces between solid and fluid domain, I have no continuity in the heat flux ...
This may be my problem? I have all the properties of the solid medium,the Refraction Index, Absorption Coefficient, and Scattering Coefficient ... but I can not get in compliance continudad Interfaces. who can help me ... I'm more than a month with this problem and I could not give solution |
Can you post the output file?
MATERIAL: Air Ideal Gas T
Material Description = Air Ideal Gas (T) Material Group = Air Data Option = Pure Substance Thermodynamic State = Gas PROPERTIES: Option = General Material EQUATION OF STATE: Molar Mass = 28.96 [kg kmol^-1] Option = Ideal Gas END SPECIFIC HEAT CAPACITY: Maximum Temperature = 2500 [K] Minimum Temperature = 290 [K] Option = Zero Pressure Polynomial Zero Pressure a1 = 3.5732 Zero Pressure a2 = -7.9639e-4 [K^-1] Zero Pressure a3 = 2.3717e-6 [K^-2] Zero Pressure a4 = -1.5164e-9 [K^-3] Zero Pressure a5 = 3.3254e-13 [K^-4] END REFERENCE STATE: Option = Specified Point Reference Pressure = 101325 [Pa] Reference Specific Enthalpy = 0. [J/kg] Reference Specific Entropy = 0. [J/kg/K] Reference Temperature = 25 [C] END TABLE GENERATION: Maximum Temperature = 2500 [K] Minimum Temperature = 290 [K] Pressure Extrapolation = On Temperature Extrapolation = Yes END DYNAMIC VISCOSITY: Option = Sutherlands Formula Reference Temperature = 25 [C] Reference Viscosity = 1.802e-05 [Pa s] Sutherlands Constant = 110 [K] Temperature Exponent = 1.5 END THERMAL CONDUCTIVITY: Option = Sutherlands Formula Reference Temperature = 25 [C] Reference Thermal Conductivity = 0.0261 [W m^-1 K^-1] Sutherlands Constant = 110 [K] Temperature Exponent = 1.5 END ABSORPTION COEFFICIENT: Absorption Coefficient = 0.01 [m^-1] Option = Value END REFRACTIVE INDEX: Option = Value Refractive Index = 1 END END END MATERIAL: Glass Plate Material Group = CHT Solids Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 2500 [kg m^-3] Molar Mass = 1 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 7.50E+02 [J kg^-1 K^-1] END REFERENCE STATE: Option = Specified Point Reference Specific Enthalpy = 0 [J/kg] Reference Specific Entropy = 0 [J/kg/K] Reference Temperature = 25 [C] END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 1.4 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 62.11 [m^-1] Option = Value END REFRACTIVE INDEX: Option = Value Refractive Index = 1.5 END END END MATERIAL: Glass Wool Material Group = CHT Solids, Particle Solids Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 50 [kg m^-3] Molar Mass = 1 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 6.70E+02 [J kg^-1 K^-1] END REFERENCE STATE: Option = Specified Point Reference Specific Enthalpy = 0 [J/kg] Reference Specific Entropy = 0 [J/kg/K] Reference Temperature = 25 [C] END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 0.04 [W m^-1 K^-1] END END END END ANALYSIS TYPE: Option = Steady State EXTERNAL SOLVER COUPLING: Option = None END END DOMAIN: Aire Coord Frame = Coord 0 Domain Type = Fluid Location = B93 BOUNDARY: Aire Default Boundary Type = WALL Location = F105.93,F108.93,F111.93,F179.93,F86.93,F90.93 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END MASS AND MOMENTUM: Option = No Slip Wall END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.9 Option = Opaque END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: Int ducto ais air Side 1 Boundary Type = INTERFACE Location = Int ducto air ais BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.9 Option = Opaque END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: Int entrada cav air Side 1 Boundary Type = INTERFACE Location = Int entrada cav air BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = Conservative Interface Flux END THERMAL RADIATION: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: Int lateral vid2 air Side 2 Boundary Type = INTERFACE Location = Int lateral air vid2 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: Int pared inferior ais air Side 1 Boundary Type = INTERFACE Location = Int pared inferior air ais BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.9 Option = Opaque END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: Int pared lateral ais air Side 1 Boundary Type = INTERFACE Location = Int pared lateral air ais BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.9 Option = Opaque END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: Int pared superior ais air Side 1 Boundary Type = INTERFACE Location = Int pared superior air ais BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.9 Option = Opaque END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: Int pared tracera ais air Side 1 Boundary Type = INTERFACE Location = Int pared tracera air ais BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.9 Option = Opaque END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: Int salida cav air Side 1 Boundary Type = INTERFACE Location = Int salida air cav BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = Conservative Interface Flux END THERMAL RADIATION: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: Int vid1 air Side 1 Boundary Type = INTERFACE Location = Int air vid1 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: Int vid1 air int Side 2 Boundary Type = INTERFACE Location = Int air vid1 int BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: Int vid2 air ext Side 2 Boundary Type = INTERFACE Location = Int air vid2 ext BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: Int vid2 air int Side 2 Boundary Type = INTERFACE Location = Int air vid2 int BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Conservative Interface Flux END MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: ared inferior aire Boundary Type = WALL Location = F109.93,F97.93,F98.93 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END MASS AND MOMENTUM: Option = No Slip Wall END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.9 Option = Opaque END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: opeening esfera Boundary Type = OPENING Location = opening esfera BOUNDARY CONDITIONS: FLOW DIRECTION: Option = Normal to Boundary Condition END FLOW REGIME: Option = Subsonic END HEAT TRANSFER: Opening Temperature = 25 [C] Option = Opening Temperature END MASS AND MOMENTUM: Option = Opening Pressure and Direction Relative Pressure = 0 [Pa] END THERMAL RADIATION: Option = Local Temperature END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END END BOUNDARY: opening inferior Boundary Type = OPENING Location = opening inferior BOUNDARY CONDITIONS: FLOW DIRECTION: Option = Normal to Boundary Condition END FLOW REGIME: Option = Subsonic END HEAT TRANSFER: Opening Temperature = 25 [C] Option = Opening Temperature END MASS AND MOMENTUM: Option = Opening Pressure and Direction Relative Pressure = 0 [Pa] END THERMAL RADIATION: Option = Local Temperature END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END END BOUNDARY: simetria aire Boundary Type = SYMMETRY Location = simetria aire END DOMAIN MODELS: BUOYANCY MODEL: Buoyancy Reference Density = 1.2 [kg m^-3] Gravity X Component = 0 [m s^-2] Gravity Y Component = -9.8 [m s^-2] Gravity Z Component = 0 [m s^-2] Option = Buoyant BUOYANCY REFERENCE LOCATION: Cartesian Coordinates = 0.0[m],0.0[m],0.0[m] Option = Cartesian Coordinates END END |
This is another part of the code
DOMAIN INTERFACE: Int lateral vid2 air Boundary List1 = Int lateral vid2 air Side 1 Boundary List2 = Int lateral vid2 air Side 2 Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.87 Option = Opaque END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: Int pared inferior ais air Boundary List1 = Int pared inferior ais air Side 1 Boundary List2 = Int pared inferior ais air Side 2 Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: Int pared lateral ais air Boundary List1 = Int pared lateral ais air Side 1 Boundary List2 = Int pared lateral ais air Side 2 Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: Int pared lateral cav ais Boundary List1 = Int pared lateral cav ais Side 1 Boundary List2 = Int pared lateral cav ais Side 2 Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: Int pared superior ais air Boundary List1 = Int pared superior ais air Side 1 Boundary List2 = Int pared superior ais air Side 2 Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: Int pared superior cav ais Boundary List1 = Int pared superior cav ais Side 1 Boundary List2 = Int pared superior cav ais Side 2 Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: Int pared tracera ais air Boundary List1 = Int pared tracera ais air Side 1 Boundary List2 = Int pared tracera ais air Side 2 Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: Int pared tracera cav ais Boundary List1 = Int pared tracera cav ais Side 1 Boundary List2 = Int pared tracera cav ais Side 2 Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: Int pared vid1 ais Boundary List1 = Int pared vid1 ais Side 1 Boundary List2 = Int pared vid1 ais Side 2 Interface Type = Solid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = Automatic END END DOMAIN INTERFACE: Int pared vid1 cav Boundary List1 = Int pared vid1 cav Side 1 Boundary List2 = Int pared vid1 cav Side 2 Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END HEAT TRANSFER: Option = Conservative Interface Flux HEAT TRANSFER INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END THERMAL RADIATION: Diffuse Fraction = 1. Emissivity = 0.87 Option = Opaque END END MESH CONNECTION: Option = Automatic END END I do not know if I have a problem with the properties \ general \ .. or if the domain interfaces between solid and fluid donimio. |
I cannot see what radiation model you are using. I think you will need a monte carlo model for this model, I suspect the other simpler models will not have sufficient physics.
You have also set the interface condition for all your interfaces to opaque. You probably need to set these to allow radiation transmittion. But I am no expert in radiation modelling, I could be wrong. |
Thanks for your comment
the radiation pattern if Monte Carlos, every body is modeled as opaque, solid body also has that model, according to what I read in the absorption coefficient one can measure the transmission of radiation by the solid body, but not I'm pretty sure. if you hear anything you tell me. I have a long but I'm working on it |
Hello Jhon,
Could you describe a little bit the problem you're trying to solve? Regards, Possa |
Problem solver runs the CFX
whenever a simulation, I get the following message
* ERROR # 001100279 has occurred in subroutine ErrAction. Message: Radiation settings across a coupled model domain were found to be inconsistent. Please change the setup and re-run. What is wrong and how I can change the setup? |
Hello Jhon,
I think the error message is pretty clear: your settings for the radiation problem are not right. I guess you are making a mistake somewhere in your radiation settings. By taking a quick look in your output file I believe radiation properties are consistent. So I think the problem is probably in interface settings and models. First of all, as Glenn already said, interfaces between semi-transparent material and other domains must not be opaque. Are you sure all interfaces are correct? Regards, Possa |
1 Attachment(s)
hello Possa
the settings I am using for the fluid and solid domain are as follows Fluid domain -Thermal Radiation option -> Monte Carlos -Number of histories 1000000 -Transfer mode Participating half Spectral-mode optio -> Multiband wavelength in vacuum 0.001 - 2.7 (micron) 2.7 - 1000 (micron) glass domain -Thermal Radiation option -> Monte Carlos -Number of histories 100,000 -Transfer mode Participating half Spectral-mode optio -> Multiband wavelength in vacuum 0.001 - 2.7 (micron) 2.7 - 1000 (micron) Interface type Fluid - solid Thermal radiation -> on conservative interface flux Material properties aire Radiation Properties - refractive index = 1 - Absorption Coefficient = 0.01 - Scattering Coefficient = 0 Material properties vidrio Radiation Properties - refractive index = 1.5 - Absorption Coefficient = 61.22 - Scattering Coefficient = 0 I attached a picture of how is the model. this is my problem, I've read several scientific articles but not the management of CFX tool. thanks for your attention and help |
Hello Jhon,
Your settings seem correct. I've taken a look in your model sketch. If you are modeling all that, then you have a lot of interfaces. Each glass plate has six interfaces. All glass-fluid domain interfaces must be set to thermal radiation->conservative flux. You must be careful to check interfaces below the "interfaces tree" and all domain interfaces related. They all must be conservative flux and not opaque. If you are setting an emissivity is because no radiation is passing through, and that's not what you want. Cavity walls, on the other hand, must be set to opaque. Another thing: to model the glass as semitransparent the fluid must be a participating media also and only monte carlo model can be applied in all domains. If you try to use another radiation model for the fluid you won't be able to use thermal radiation-> conservative flux. So all domains must use monte carlo for this to work (learned by experience). If all interfaces are correct it should run. Regards, Possa |
1 Attachment(s)
hello Possa
and finish the simulation, thank you for your cooperation and others. I attached a picture of how the simulation gave. The parameters used were as you mentioned earlier. I have only one question. for semitrasmaparente material has the following properties, absorptivity (0.14) - reflectivity (0.08) - transmisivity (0.78) more Emissivity (0.85) where you enter the value of emissivity in CFX, CFX progrma or it assumes by default? thank you very much for your collaboration, were more than three months of work and information search. if you see something strange in the pictures I can tell my. |
Hello Jhon,
For any participating media (including semi-transparent) emissivity is not needed to solve the radiation problem as it is derived from the absorption coefficient (not absorptivity). You only use emissivity, absorptivity, reflectivity and transmisivity for a participating media if you are treating it as a whole piece (example: solving a glass wall without solving the radiation inside the glass only the energy balance on the wall). What you need to set for participating media is absorption coefficient, refraction index and scattering coefficient. If you need any clarifying on the subject I suggest the book "Radiative Heat Transfer" from Siegel and Howell. Regards, Possa |
cfx
Hi dear all,
i have to model super heater tube bundles in cfx. How i can consider the radiation? please guide me step to step!!!!!! thanks a lot:) |
The simple approach is to model it as a simple heat load.
Or you can use a radiation model. The discrete transfer model is adequate for many applications. Have a look at the tutorials for how to set it up. |
Different Fluids In CFX
I put different Fluids domain in CFX, but when I run it :confused::confused::confused:
Error appears +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Equation subsystem: "Momentum and Mass - 1" has not been found on | | both sides of interface "Default Fluid Fluid Interface". Check t- | | hat you have set consistent physics across all domains that use t- | | his interface. | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine DEF_ALGM_SUBSYS_ZIF | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ |
