September 29, 2012, 14:29 |
Porous hyperelasticity
Shashwat
Rep Power: 14 |
hello
Does any one have any experience with modelling arterial wall as porous hyperelastic materials in cfx., I am curious to see how it is possible to incorporate fluid flow into the models . Lokking forwards to hearing from you Thanks Regards Govind |
October 1, 2012, 07:39 |
Rep Power: 143 |
Ummm, what is porous hyperelasticity? Can you explain how that works?
October 5, 2012, 00:27 |
Shashwat
Rep Power: 14 |
Dear all
I am going to use Mooney -Rivlin 3 parameter material for my analysis. I would like to use porosity and permiability value on this model. How can I do the domain setup in the cfx pre. (Note: Solid and porous part involved in the model) Thanks Regards Govind |
October 5, 2012, 06:12 |
Rep Power: 143 |
You mean you want to do a FSI model where the FEA bit uses a Mooney-Rivlin material and the solid part is a porous material as well?
I cannot see a way to make a solid both FSI and porous. |
October 6, 2012, 03:32 |
Porous
Shashwat
Rep Power: 14 |
Dear friend
Yes . I want to do two way FSI analysis. I would like to introduce porocity and permiability as well on the solid. I found an option in cfx pre while selecting the porous domain, I can find AN OPTION CALLED solid definition . Shall I use this option to define the solid Thanks Regards Govind |
October 6, 2012, 07:45 |
Rep Power: 143 |
As I said, I cannot see a way to make a solid both FSI and porous. An FSI body is represented in CFX by its external surfaces only as that it the interface which interacts with the solid and fluid. So CFX does not have the solid to do a porous model, and I do not think you can transfer it to ANSYS mechanical to do it there either.
So I do not think this is possible. But feel free to try, I would be very happy if you proved me wrong. |
October 21, 2012, 04:16 |
porous fsi
bitak
Rep Power: 16 |
hello.
could you couple Fsi two way with poros wall in CFX? I think you can use multilayer for porous wall and then one of them will have FSi. what's your idea? |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 04:09 |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 04:10 |
Modelling sound propagation through layered porous media | nkinar | Main CFD Forum | 0 | July 4, 2010 14:45 |
species mass source in porous media ? | PK | FLUENT | 0 | February 16, 2007 11:12 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 15:16 |
