October 11, 2012, 07:36 |
Boundary Condition
Prashant Kumar Singh
I have to give BC for compressor inlet & outlet
......in which velocity profile at inlet is mandatory to give n aslo i need mass flow rate as my BC(inlet/outlet) for comparison for different results based on mass flow @inlet plane BC velocity profile & any pressure(Total/static) both r not taking together (i want to give both so that i can give mass flow rate at outlet....plz suggest me some method to give Both BC) @outlet plane BC mass flow rate & any pressure(Total/static) ......both are not taking..... when i give run without Pas BC then cfx is telling atleast one P should be as BC |
October 11, 2012, 07:55 |
#2 | |
Christoph
chapter 2.2 |
October 11, 2012, 09:54 |
Chris DeGroot
There should be no need to specify mass flow at the outlet. You have specified it at the inlet and the code will conserve mass. Specifying it at the outlet is over constraining your problem which is why it won't let you do it. Did you try just giving an average static pressure condition at the outlet?
October 12, 2012, 00:31 |
thanks energy382 and cdgeroot for ur reply
currently i have given run on following BC inlet BC velocity profile & outlet BC static P(101325Pa) but in this case i m unable to draw compressor map thats why i want to give mass flow at one BC so that i can vary it n plot a compressor map velocity profile at inlet and mass flow at outlet BC is not taken by cfx it is asking one P as BC |
October 12, 2012, 08:47 |
Chris DeGroot
Yes I understand. Since you are running compressible flow, specifying the velocity profile does not fix your mass flow rate. Is there a reason that you want to specify a profile rather than just give the mass flow rate? Using a mass flow inlet and static pressure outlet is a stable configuration that should give you what you want, apart from the desired inflow profile.
October 12, 2012, 13:08 |
Yes I want to simulation distortion by giving velocity profile at the inlet...that velocity profile is not uniform it have some specific circumferential velocity distribution by which i am trying to simulate distortion at the compressor inlet.
what you told is correct that is robust BC and it works. here in this case i will obtained one mass flow for one particular velocity profile and when i will change velocity profile mass flow will also change accordingly. and i have to obtained compressor map pressure ratio Vs mass flow rate for one velocity profile or distortion pattern so that i can compare how much this kind of distortion design deviates compressor performance from clean inlet compressor performance. thanks a lot for your valuable reply |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
How exactly the "pressure outlet" bdry condition compute properties on the boundary? | yating9901 | FLUENT | 3 | June 28, 2010 12:26 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 11:44 |
