Run-time memory allocation error with 40GB RAM |
October 11, 2012, 07:52 |
Juan Campos
Hi everybody,
I need your help please! I'm trying to run an CFX simulation and I always received this: +--------------------------------------------------------------------+ | Memory Allocated for Run (Actual usage may be less) | +--------------------------------------------------------------------+ Data Type Kwords Words/Node Words/Elem Kbytes Bytes/Node Real 1527918.2 453.00 82.17 5968430.5 1812.02 Integer 583426.2 172.98 31.38 2279008.8 691.91 Character 5089.8 1.51 0.27 4970.5 1.51 Logical 96.0 0.03 0.01 375.0 0.11 Double 729.6 0.22 0.04 5700.0 1.73 +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | *** Run-time memory allocation error *** | | Not enough free memory is currently available on the system. | | Could not allocate requested memory - exiting! | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 2. No results file | | has been created. | +--------------------------------------------------------------------+ I know that is a very common issue, but I've red a lot and I don't got it!. I have 40 GB that should be enoguh, shouldn't be? thank you in advance!!! |
October 11, 2012, 10:01 |
You have 40 GB of RAM????
Or do you mean Disk Space.... The Memory meant by ANSYS is RAM and not Hard Disk Space...so if you have less than approx. >9GB of RAM it won't work. |
October 11, 2012, 10:08 |
Juan Campos
thank you!
I mean 40GB or RAM; I had 8GB and I've installed 32GB more. |
October 11, 2012, 15:58 |
Paulo
Your mesh have high Refinement? maybe your mesh have too many elements per quad.
October 12, 2012, 08:51 |
Chris DeGroot
Must be something else going on. Based on the memory allocated table you posted it seems like it is only trying to allocate a bit more than 8GB. So unless you have a lot of other things running, you should have plenty of RAM.
October 13, 2012, 03:31 |
S.Bogoda
Are you dealing with steady state or Transient State?
October 24, 2012, 06:24 |
Juan Campos
I am dealing with steady state,
thank you to everyone |
October 24, 2012, 12:53 |
Paulo
try change memory allocated factor.
October 24, 2012, 15:58 |
#9 | |
Mandeep Singh
I guess mesh is highly refined so try to have mapped mesh or do not use parallel computing
October 25, 2012, 03:11 |
Holger Dietrich
which operating system do you use? Windows 7 (32 bit) and Windows Vista (32 bit) are able to handle only 4 GB RAM. 2 of these 4 GB RAM can be used for applications. So your 40 GB RAM are worthless, if you use Windows Vista, 7 (or even XP). If you use Windows: What you can try is the CFF explorer suite. With this tool you can manipulate program files and allow them to allocate more then 2 GB RAM. Load the particular program file, edit the file header characteristics and enable the option "app can handle > 2 GB of adress space" (see attachment). You should do a backup copy of your program file before! If it still does not work - as mentioned before - you can try to play with the solver's memory allocation factor in CFX. Hope that helps, Daryl Musashi Last edited by DarylMusashi; November 9, 2015 at 16:20. |
October 25, 2012, 05:59 |
#11 |
Rep Power: 143 |
I do not think Daryl's trick will allow you to access >2GB. The CFX code will not have been written to support this so it will not work.
Your choices are: * Use distributed parallel to split it up over many machines * Use local parallel to split it up to many processes on the local machine where each process is less than 2GB. * Move to a 64 bit OS with 64 bit CFX. * Use a coarser mesh. |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 04:35 |
RAM memory problem | alpha | Main CFD Forum | 8 | February 12, 2008 11:07 |
AMG versus ICCG | msrinath80 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2006 15:15 |
