Euler equation
Old   June 12, 2006, 09:20
Default Euler equation
petr
i would like to know whether it is possible to solve fluid flow problem with the help of Euler equation model (non-viscous fluid)in CFX.
Thank You, Petr.
Old   June 12, 2006, 09:39
Default Re: Euler equation
CFD Man
Set the flow to laminar and the viscosity to a very small number.
Old   June 12, 2006, 09:55
petr
Thank You.
One more question. Is it easy to prescribe viscosity ? Sorry for this question, but at recent time i am not able to check it (once more again sorry).
Petr.
Old   June 12, 2006, 10:23
Joe
Yes. Create a new material in the material editor and set the transport properties as needed.
For a pseudo-Euler analysis dont set the viscosity to exactly 0, just a suitably small value.
Old   June 12, 2006, 10:25
petr
Thank You Joe and CFD Man.
Old   October 16, 2012, 11:57
su yunde
junc is on a distinguished road
hello!
i am conducting a simulation through euler equation in cfx and meet some questions.
i set a very low Dynamic Viscosity value, the 'laminar' turbulence model option .besides, i also set the 'Free Slip Wall' option at all walls. however, i get the following message in cfx solver:
| ERROR #002100004 has occurred in subroutine Out_Scales_Flu. |
| Message: |
| The Reynolds number is outside of the range expected based on the |
| Option selected for the TURBULENCE MODEL. Check this setting, |
| the values of the properties, mesh scale, consistency of units |
| and solution values in the input file. Execution will proceed. |
does this message effects the result?
thank you for your reply!
junc is offline   Reply With Quote
Old   October 16, 2012, 18:26
It is just a warning. You can ignore it - but make sure you know that the flow is in fact laminar.
Old   October 17, 2012, 00:19
su yunde
thank you, ghorrocks!
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Jacobian of 1D Euler Equation of Gas Dynamics Simplicity. Main CFD Forum 3 September 6, 2011 14:12
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Linearized Euler Equation vasanth Main CFD Forum 0 May 30, 2004 15:25
