An error has occurred in cfx5solve:
Old   October 17, 2012, 14:37
Default An error has occurred in cfx5solve:
volo87
volo87 is on a distinguished road
Good morning everyone,
after several days spent trying to find a possible solution to the problem i decided to ask for help. It seems something for expert and out of my knowledge! I tried the following things:
-install again ansys;
-install again the license;
-install again the graphic drivers;
-do the model setup again from scratch;
-search if anybody else had the same problem (C000005 seems to be quite common but not with an "aborted for unknown reason" error!)
I am currently using ANSYS 13.0, FLUID FLOW (CFX). Here the output message (I now it is long, but I think it is better to give as much information as possible):
This run of the CFX-13.0 Solver started at 20:11:06 on 17 Oct 2012 by
user volo87 on VOLO87-VAIO (intel_xeon64.sse2_winnt) using the command:
"C:\Program Files\ANSYS Inc\v130\CFX\bin\perllib\cfx5solve.pl" -batch
-ccl runInput.ccl -fullname "Fluid Flow CFX_021"
Setting up CFX Solver run ...
| CFX Command Language for Run |
LIBRARY:
MATERIAL: Air at 25 C
Material Description = Air at 25 C and 1 atm (dry)
Material Group = Air Data, Constant Property Gases
Option = Pure Substance
Thermodynamic State = Gas
PROPERTIES:
Option = General Material
EQUATION OF STATE:
Density = 1.185 [kg m^-3]
Molar Mass = 28.96 [kg kmol^-1]
Option = Value
END
SPECIFIC HEAT CAPACITY:
Option = Value
Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1]
Specific Heat Type = Constant Pressure
END
REFERENCE STATE:
Option = Specified Point
Reference Pressure = 1 [atm]
Reference Specific Enthalpy = 0. [J/kg]
Reference Specific Entropy = 0. [J/kg/K]
Reference Temperature = 25 [C]
END
DYNAMIC VISCOSITY:
Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1]
Option = Value
END
THERMAL CONDUCTIVITY:
Option = Value
Thermal Conductivity = 2.61E-02 [W m^-1 K^-1]
END
ABSORPTION COEFFICIENT:
Absorption Coefficient = 0.01 [m^-1]
Option = Value
END
SCATTERING COEFFICIENT:
Option = Value
Scattering Coefficient = 0.0 [m^-1]
END
REFRACTIVE INDEX:
Option = Value
Refractive Index = 1.0 [m m^-1]
END
THERMAL EXPANSIVITY:
Option = Value
Thermal Expansivity = 0.003356 [K^-1]
END
END
END
END
FLOW: Flow Analysis 1
SOLUTION UNITS:
Angle Units = [rad]
Length Units = [m]
Mass Units = [kg]
Solid Angle Units = [sr]
Temperature Units = [K]
Time Units = [s]
END
ANALYSIS TYPE:
Option = Steady State
EXTERNAL SOLVER COUPLING:
Option = None
END
END
DOMAIN: CFF
Coord Frame = Coord 0
Domain Type = Fluid
Location = Assembly 3
BOUNDARY: CFF_GW Side 1
Boundary Type = INTERFACE
Location = F771.659
BOUNDARY CONDITIONS:
HEAT TRANSFER:
Option = Conservative Interface Flux
END
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: FREESTREM_CFF Side 2
Location = F807.659
HEAT TRANSFER:
END
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: ROTATING_W
Boundary Type = WALL
I had to cut some code lines since I exceeded the maximum characters allowed!
Domain Type = Fluid
Location = Assembly 2
BOUNDARY: FREESTREM_CFF Side 1
Location = F47.36
HEAT TRANSFER:
END
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: INLET
Boundary Type = INLET
Location = F39.36
FLOW REGIME:
Option = Subsonic
END
HEAT TRANSFER:
Option = Static Temperature
Static Temperature = 25 [C]
END
MASS AND MOMENTUM:
Normal Speed = 10 [m s^-1]
Option = Normal Speed
END
TURBULENCE:
Option = Medium Intensity and Eddy Viscosity Ratio
END
END
END
BOUNDARY: OPENING
Boundary Type = OPENING
Location = F46.36
FLOW DIRECTION:
Option = Normal to Boundary Condition
END
FLOW REGIME:
Option = Subsonic
END
HEAT TRANSFER:
Opening Temperature = 25 [C]
Option = Opening Temperature
END
MASS AND MOMENTUM:
Option = Opening Pressure and Direction
Relative Pressure = 1 [bar]
END
TURBULENCE:
END
END
END
BOUNDARY: SLOPE_WALL
Location = F41.36
HEAT TRANSFER:
Option = Adiabatic
END
MASS AND MOMENTUM:
Option = No Slip Wall
END
WALL ROUGHNESS:
Option = Smooth Wall
END
END
END
BOUNDARY: SYM1
Boundary Type = SYMMETRY
Location = F38.36
END
BOUNDARY: TRAILING_EDGE
Location = F44.36
HEAT TRANSFER:
Option = Adiabatic
END
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: UTLET
Boundary Type = OUTLET
Location = F45.36
FLOW REGIME:
Option = Subsonic
END
MASS AND MOMENTUM:
Option = Average Static Pressure
Pressure Profile Blend = 0.05
END
PRESSURE AVERAGING:
Option = Average Over Whole Outlet
END
END
END
BOUNDARY: WALL
Location = F37.36
HEAT TRANSFER:
Option = Adiabatic
END
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: YMM2
Location = F40.36
END
DOMAIN MODELS:
BUOYANCY MODEL:
Option = Non Buoyant
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
FLUID DEFINITION: Fluid 1
Material = Air at 25 C
Option = Material Library
MORPHOLOGY:
Option = Continuous Fluid
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
HEAT TRANSFER MODEL:
Include Viscous Work Term = On
Option = Total Energy
END
THERMAL RADIATION MODEL:
Option = None
END
TURBULENCE MODEL:
Option = k epsilon
END
TURBULENT WALL FUNCTIONS:
High Speed Model = Off
Option = Scalable
END
END
END
DOMAIN: GW_ROTATING_REGION
Domain Type = Fluid
Location = Assembly
BOUNDARY: CFF_GW Side 1 1
Location = F174.146
HEAT TRANSFER:
END
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: GW_STATIONARY_REGION Side 1
Location = F173.146
HEAT TRANSFER:
END
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: ROTATING_WALL
Frame Type = Rotating
Location = \
F147.146,F149.146,F151.146,F152.146,F153.146,F154. 146,F155.146,F156.1\
46,F157.146,F158.146,F159.146,F160.146,F161.146,F1 62.146,F163.146,F16\
4.146,F165.146,F166.146,F167.146,F168.146,F169.146 ,F170.146,F171.146,\
F172.146
HEAT TRANSFER:
Option = Adiabatic
END
MASS AND MOMENTUM:
END
WALL ROUGHNESS:
END
END
END
BOUNDARY: SYMMETRY_GW_1
Location = F148.146
END
BOUNDARY: SYMMETRY_GW_2
Location = F150.146
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Angular Velocity = 50 [rev min^-1]
Option = Rotating
AXIS DEFINITION:
Option = Coordinate Axis
Rotation Axis = Coord 0.2
END
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
END
Option = None
END
TURBULENCE MODEL:
Option = k epsilon
END
Option = Scalable
END
END
END
DOMAIN: STATIONARTY_REGION
Domain Type = Fluid
Location = Assembly 4
BOUNDARY: GW_STATIONARY_REGION Side 2
Location = F67.66
HEAT TRANSFER:
END
MASS AND MOMENTUM:
END
TURBULENCE:
END
END
END
BOUNDARY: SYM2
Location = F69.66
END
BOUNDARY: SYMM1
Location = F68.66
END
DOMAIN MODELS:
BUOYANCY MODEL:
END
DOMAIN MOTION:
Option = Stationary
END
MESH DEFORMATION:
Option = None
END
REFERENCE PRESSURE:
END
END
MORPHOLOGY:
END
END
FLUID MODELS:
COMBUSTION MODEL:
Option = None
END
END
Option = None
END
TURBULENCE MODEL:
Option = k epsilon
END
Option = Scalable
END
END
END
DOMAIN INTERFACE: CFF_GW
Boundary List1 = CFF_GW Side 1 1
Boundary List2 = CFF_GW Side 1
Interface Type = Fluid Fluid
INTERFACE MODELS:
Option = Translational Periodicity
MASS AND MOMENTUM:
MOMENTUM INTERFACE MODEL:
Option = None
END
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: FREESTREM_CFF
Boundary List1 = FREESTREM_CFF Side 1
Boundary List2 = FREESTREM_CFF Side 2
INTERFACE MODELS:
MASS AND MOMENTUM:
Option = None
END
END
END
MESH CONNECTION:
Option = GGI
END
END
DOMAIN INTERFACE: GW_STATIONARY_REGION
Boundary List1 = GW_STATIONARY_REGION Side 1
Boundary List2 = GW_STATIONARY_REGION Side 2
INTERFACE MODELS:
MASS AND MOMENTUM:
Option = None
END
END
END
MESH CONNECTION:
Option = GGI
END
END
OUTPUT CONTROL:
RESULTS:
File Compression Level = Default
Option = Standard
END
END
SOLVER CONTROL:
Turbulence Numerics = First Order
ADVECTION SCHEME:
Option = High Resolution
END
CONVERGENCE CONTROL:
Length Scale Option = Conservative
Maximum Number of Iterations = 100
Minimum Number of Iterations = 1
Timescale Control = Auto Timescale
Timescale Factor = 1.0
END
CONVERGENCE CRITERIA:
Residual Target = 1.E-4
Residual Type = RMS
END
DYNAMIC MODEL CONTROL:
Global Dynamic Model Control = Yes
END
END
END
COMMAND FILE:
Version = 13.0
Results Version = 13.0
END
SIMULATION CONTROL:
EXECUTION CONTROL:
EXECUTABLE SELECTION:
Double Precision = On
END
INTERPOLATOR STEP CONTROL:
Runtime Priority = Standard
MEMORY CONTROL:
Memory Allocation Factor = 1.0
END
END
PARALLEL HOST LIBRARY:
HOST DEFINITION: volo87vaio
Remote Host Name = VOLO87-VAIO
Host Architecture String = winnt-amd64
Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX
END
END
PARTITIONER STEP CONTROL:
Multidomain Option = Independent Partitioning
Use Large Problem Partitioner = Off
END
MEMORY CONTROL:
END
PARTITIONING TYPE:
MeTiS Type = k-way
Option = MeTiS
Partition Size Rule = Automatic
END
END
RUN DEFINITION:
Run Mode = Full
Solver Input File = Fluid Flow CFX.def
END
SOLVER STEP CONTROL:
MEMORY CONTROL:
END
PARALLEL ENVIRONMENT:
Number of Processes = 1
Start Method = Serial
END
END
END
END
| Warning! |
| Return value C0000005 >FFFF in parse_rv, treating as not-run. |
| An error has occurred in cfx5solve: |
| C:\Program Files\ANSYS Inc\v130\CFX\bin\winnt-amd64\ccl2flow.exe |
| aborted for unknown reasons.
| Warning! |
| After waiting for 60 seconds, 1 solver manager process(es) appear |
| not to have noticed that this run has ended. You may get errors |
| removing some files if they are still open in the solver manager. |
This run of the ANSYS CFX Solver has finished.
I am not an expert. I did a couple of simulations before but nothing like that has ever happened to me. Thank you very much for your attention.
volo87
volo87 is offline   Reply With Quote
Old   October 17, 2012, 17:43
Does a simple simulation like the tutorial examples run?
Old   October 18, 2012, 07:56
volo87
Yup. Everything runs just fine except for this one. I have no idea of what is causing this error. Next week I'm going to try to run the file at university, let's see if with an older version it works. I will let you know.
Old   October 18, 2012, 09:33
Christoph
energy382 is on a distinguished road
I'm missing stator-rotor interface!? have you disabled "automatic generation of interface". If so, it seems you forget to build that interface. That would explain the error message
energy382 is offline   Reply With Quote
Old   November 27, 2012, 05:33
ranjith
ranjith is on a distinguished road
Did you solve the issue. I am getting the same error
ranjith is offline   Reply With Quote
Old   June 14, 2013, 17:44
Elena
Elena13 is on a distinguished road
Where do I do this you say?
thank you
Elena13 is offline   Reply With Quote
Error #001100279 bharath CFX 9 March 25, 2015 05:31
An error has occurred in cfx5solve pandu CFX 4 August 21, 2012 20:24
An error has occurred in cfx5solve: HMR CFX 5 February 21, 2012 03:41
Error in CFX Solver Leuchte CFX 5 November 6, 2010 06:12
An error has occurred in cfx5solve: yuan CFX 1 June 8, 2008 15:12
