October 22, 2012, 07:33 |
Heat FLux through wall
above
I have just started to use CFX. I am trying a few test cases as part of an assignment. One of them involves a cylinder inside a rectangular duct. The cylinder is heated while the duct is cooled. I have done simulations and it all works out. But what I cannot find out is how to find the heat flux as from one of the walls. I though you could use functions as I found out the mass flow rate for another example before. But the variable heat flux does not appear. Any help on how to finish this will be appreciated.
October 22, 2012, 12:50 |
Erik
Rep Power: 23 |
are you using CFD POST to see your results?
You could try making a contour to display "wall heat flux" or "Heat flux" you can try to display these contours on the fluid interface side, or the solid interface side. It should work with one of these combinations. |
cfx |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
how to export "wall heat flux" to tecplot? | victor | CFX | 3 | November 27, 2008 09:45 |
CFX - wall heat flux | divarano | CFX | 2 | December 4, 2006 16:14 |
Basic question: UDF for wall heat flux | Carl | FLUENT | 1 | August 5, 2006 19:01 |
