-   -   Heat transfer coefficient for porous domain (http://www.cfd-online.com/Forums/cfx/108843-heat-transfer-coefficient-porous-domain.html)
l.te November 2, 2012 11:18
Hi dears,
anyone can tell me how to calculate the heat transfer coefficient for a porous domain with a solid continous component (fiberglasses) and a fluid continous component (resin)?
I know that this coefficient varies with the temperature, so I want to do an expression for it, but how to do it?.
I read the help but I didn't find my case!
P.S. I know the interfacial area density of the porous.
singer1812 November 2, 2012 12:00
Perhaps
h=q/(Twall-Tref)
You choose the Tref yourself.
l.te November 2, 2012 12:55
Originally Posted by singer1812 (Post 389913)
Perhaps
h=q/(Twall-Tref)
Hi singer1812, the problem is that my cylindrical porous domain is heated at the wall by an imposed thermal profile (given through an expression "Twall"), so I don't know "q" a priori.
Besides, also T of the resin varies along the profile of the part.
singer1812 November 2, 2012 12:59
areaAve(Wall Heat Flux)@your area
or if you dont want area averaged h, then create a variable for h using
Wall Heat Flux
And what ever Tref you want.
l.te November 2, 2012 15:00
Wall Heat Flux
Hello, areaAve is a post-processor command, I need to have heat transfer coefficient in pre-processor, to insert it in the porous domain tab.
And this heat transfer coeffcient is between solid an fluid part inside the porous domain, so I don't have an area as boundary location between the two phases.
singer1812 November 2, 2012 15:19
Ahh, I misunderstood. I thought you wanted to pull out an h off of your solution.
You are looking for an emperically based h. I am not totally familar with fluid-solid h correlations for porous medium, and they will be quite specific to certain applications.
l.te November 3, 2012 11:14
thanks anyway singer1812
hmasenger June 20, 2014 03:05
hi i.te
did you find any answer for your problem? i think i have same trouble with variable h.any clue would really help
