Why is the pressure larger than the total pressure |
November 9, 2012, 04:41 |
Rep Power: 14 |
I am simulating a gas flow through a rotating multi-channels with CFX, both the inlet and outlet are the Opening boundary condition. While the inlet has a reletive pressure of 4atm, and the outlet of 2atm, rotation speed is 10000r/min. When I look the result of my computation, at the inlet plane, the pressure is larger than the total pressure, how could this happened?
November 9, 2012, 05:30 |
Rep Power: 143 |
Can you show some images of what you are seeing?
November 9, 2012, 06:07 |
Rep Power: 14 |
[IMG] These are the inlets, the range of the contour is local, from the picture we can see that the pressure is larger than the total pressure in the inlets plane, I don't know why. Last edited by greatwall; November 9, 2012 at 06:12. Reason: the pictures didnot show well |
November 9, 2012, 06:09 |
Rep Power: 143 |
Sorry, I do not download files from other websites. Please post them as attachments to this post (using "Go Advanced").
November 9, 2012, 06:12 |
Rep Power: 14 |
[IMG]http://b323.photo.store.qq.com/psb?/V13rxVKa3rhjqK/dwmy9NgB8guQ2FZrPtVmGUFOOzoOhbMyE*ps3QsggBA!/b/dGl*isCnAAAA&bo=hAOAAQAAAAADACM![/IMG]
November 9, 2012, 06:36 |
Rep Power: 143 |
We will need to see a bit more of the geometry to make any sense of it. Can you post an image which shows what the flow is actually doing?
Also, is this boundary on a rotating frame of reference? Multiphase? Does it have reverse flow? |
November 9, 2012, 16:22 |
#9 |
Rep Power: 143 |
Where is the axis of rotation for the domain?
November 9, 2012, 21:36 |
#10 |
Rep Power: 14 |
The axis of the rotation is on the negative y direction
November 11, 2012, 06:10 |
#11 |
Rep Power: 143 |
I see. I cannot explain what you are seeing.
What does the total pressure in the stationary frame of reference look like? |
November 12, 2012, 21:49 |
#12 |
Rep Power: 14 |
The problem has been solved. Thank you! When I put the total pressure in the stationary frame of reference, the result is correct.
Display Modes | |
Total pressure in rel frame and total pressure | Salut | CFX | 14 | May 8, 2023 03:29 |
Does star cd takes reference pressure? | monica | Siemens | 1 | April 19, 2007 12:26 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
total pressure in CFX | Atit Koonsrisuk | CFX | 0 | January 1, 2005 06:46 |
Total pressure to static pressure ratio | roadracer | Siemens | 1 | April 17, 2003 06:31 |
