August 11, 2010, 07:49 |
Assistance in Vacuum pump simulation
Venkat
Rep Power: 16 |
Hello all,
I'm using ANSYS CFX 12.1. I would like to address the challenge in vacuum pump performance especially vacuum generated. Client expects the vacuum pump to work consistently and should generate 680 mm Hg without fail. When tested in rig, certain vacuum pump models (rotary vane type) cannot meet required targets. Instead, it can generate up to 650mm Hg in the test rig. I would like to diagnose the problem using CFD analysis and find whether the flow factors if any (pressure drop/rise) are causing such mediocre performance. I'm sure that the vacuum pump can be simulated using dynamic mesh instead of MRF model as i need to capture the fluid inlet / outlet gap with vane closely. How can we model the vacuum pump when pump speed, oil flow rate, oil temperature and pressure data are known ? I would appreciate if any body could share their experiences in modeling vacuum pump. |
August 11, 2010, 08:06 |
Rep Power: 143 |
Sounds like a workable simulation.
But what are you expecting CFD will tell you? Does not your result simply mean the vanes are not sealing tightly enough - I don't think you need CFD to tell you that..... Or is something more complex happening? |
November 14, 2011, 04:21 |
#3 | |
ragothsingh
Rep Power: 15 |
I am doing a project in Vacuum pump(Regenerative pump). I am having the dimension of the pump. I want to conduct CFD analysis to improve the performance. Please help in this regard |
November 14, 2011, 04:26 |
#4 | |
ragothsingh
Rep Power: 15 |
NEED HELP I am doing my thesis(ME/MTech). in Vacuum pump. I am having dimension of Regenerative pump. I want to conduct CFD analysis. Please help me in this regard. ragothsingh@rediffmail.com |
November 14, 2011, 05:20 |
Rep Power: 143 |
If you want to learn CFD in general then talk to your university. If you have a specific question then ask it.
November 20, 2012, 11:50 |
#6 | |
MNA
Vacuum pump simulation | Alasdair | Main CFD Forum | 3 | March 3, 2011 00:00 |
Overflow problem in steady simulation | ReeKo | CFX | 11 | October 8, 2008 17:57 |
Rotary vane pump simulation | usker | Siemens | 1 | February 14, 2007 03:52 |
Vacuum pumpdown simulation | Derek Coon | Siemens | 2 | September 29, 2005 16:52 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 10:06 |
