Which Multiphase Model?Ethylene glycol+Silver nanoparticles |
October 28, 2012, 13:33 |
Rep Power: 14 |
I'd like to model a combination of ethylen glycol and silver nanoparticles .(the combination lies on a solid plate and then heats)
The viscosity of ethylen is in order of 1 cP but the combination of that should become about 70 cP. I dont know which kind of multiphase flow models is appropriate for this modeling and how i can find out the characteristics of the combination after setting up the multiphase flow.(like boiling point and etc. ) thank you in advance. |
October 28, 2012, 16:10 |
Rep Power: 143 |
nanoparticles are too small to model with a multiphase model. I would consider modelling this with an additional variable for the nanoparticles, and make all the material properties functions of the nanoparticel concentration.
October 29, 2012, 06:58 |
#3 | |
Rep Power: 14 |
Do you know any related paper or book or link regarding these issues? you mean i should define just a user-defined fluid and try to define all the variables as functions of my nanoparticles? I know just the percentage of nanoparticles in the ethylen glycol and the variables(characteristics) of the final mixture. |
October 29, 2012, 16:13 |
#4 | |
Rep Power: 143 |
There are a few posts on the forum about nanoparticles. You will need to do a literature search to find what the state of the art is, however.
But you can forget about multiphase models as things like interphase slip and heat transfer do not happen, instead Brownian motion and things like that are important. Brownian motion can be modelled as diffusion on an additional variable. |
October 31, 2012, 11:47 |
Erik
Rep Power: 23 |
A agree with Glenn,
You need to tell us more about what you are trying to do. Is the combination always at the same mixture concentration, or are they mixing? Are you trying to boil the ethylene glycol away and leave the silver particles? |
November 5, 2012, 07:12 |
Rep Power: 14 |
Thank you for your attention.
Yes i like to boil the ethylene glycol and leave the silver particles. I want to have heat transfer simulation of the sintering process. In this process, a moving laser beam heats a high-visous fluid(mixture of ethylen glycol +silver nanoparticles) on a solid plate . As you see in the picture below, there are 2 blocks.the bigger one(blue one) is solid plate. and the other one(green one) is the high-viscous fluid. A laser beam should heat the top part of the fluid line(high-viscous fluid). So my first problem, as i asked above, is that how can i model that high viscous fluid? Because the charactristics of the fluid should be changed by temperature changes. And my second problem: I think i cannot use the 'heat flux BC' because my 'fluid line' is not solid and i cannot set any constant BC on the topwall.furthurmore i should probably consider melting and it's the other reason that i cannot use the heat flux BC. So i dont know how can i heat the 'fluid line' by a moving laser beam. I hope i could clarify my problem. Thank you in advance. Last edited by fshak92; November 5, 2012 at 09:50. |
November 5, 2012, 19:24 |
Erik
Rep Power: 23 |
I am not experienced in these types of models, or the sintering process, so I can not help you much. But like Glenn said, you can make a user material and use a function to change your material properties with temperature, or the additional variable, or both.
I would think the laser beam would not only affect the surface, but would penetrate into the volume of the fluid, and perhaps onto the surface of the plate underneath. You can do this with source terms where you define a Z coordinate which will change along the length with time. Then use some expressions like step functions to add a volumetric heat source to all the fluid volume or plate surface within a distance (radius of your laser beam). As far as boiling away the fluid, and leaving the particles behind I can not help you there, sorry. |
November 6, 2012, 05:44 |
Rep Power: 143 |
This is a really complex model. I hope you are expecting to take several months on this (if you are experienced at CFD) or a few years (if you are a beginner). You are going to have lots of physics sub models to develop and validate, then combine them together and validate again.
But a question - how much fluid flow is involved in this? It seems the paste just sits there and gets cooked, so very little flow actually happens. If this is the case then you would probably get just as good answers with a simple heat equation solver linked to some lumped physics parameters for the sintering. If fluid flow is not significant then do not do this with CFD, it will just make it a zillion times harder. |
November 15, 2012, 05:06 |
#9 | |
Rep Power: 14 |
Yes the movement of fluid is not considerable because of its high viscousity and the heat transfer part is significant. I would appreciate if you explain more about the ways you mentioned above. |
November 15, 2012, 05:26 |
#10 |
Rep Power: 143 |
It sounds like you need to look at what the fundamental physics at work here is. If fluid flow is not significant then forget about CFD software. The physics is much easier to model if you assume things do not move, then a simple heat transfer model with some phase change physics can do it. And they can often be written by hand.
which Multiphase model?Ethylene glycol+Silver nanoparticles | fshak92 | FLUENT | 0 | October 28, 2012 06:18 |
