November 21, 2012, 04:23 |
Default thermodynamic state in CFX
Jey
I am performing a CFD analysis for which I have not activated the "Thermodynamic State" of the material. I have specified Density, Dyn. Visc., Th. Cond., sp. Heat values varying with temperature.
Can I know what state will CFX assume by default? Thanks, J |
November 21, 2012, 05:18 |
Rep Power: 143 |
If you define an incompressible simulation then the state is irrelevant - the fluid is defined by density and viscosity only. If you define a compressible simulation then you need density to be a function of pressure and/or temperature. This could be either modelling a gas or a liquid (ie water hammer).
The phase of the material only really matters when you start doing multi phase simulations. If you are single phase then it does not matter. |
November 21, 2012, 09:23 |
Jey
Thanks Glen.
I am solving a buoyancy case for an enclosed oil filled cavity. Trying to solve for natural convection with a heat generation (heat flux BC) at the middle of the cavity. There is no phase change involved in this problem. I have created User Defined functions for Viscosity, Density, Th. Cond & sp. heat as tabular values varying w.r.t. temperature. I have not used any pressure other than reference pressure during initialization. What kind of simulation will CFX assume for the above problem, whether incompressible or compressible? |
November 21, 2012, 17:28 |
Rep Power: 143 |
CFX will do a compressible simulation if you define density as a function of pressure/Temperature, AND you choose Total Energy as your thermal model. Otherwise you will be running incompressible.
The simple approach for buoyancy is to use Bossinesq buoyancy which keeps the simulation incompressible. But if you want to get maximum accuracy (and I presume you do if you are setting variable properties) then you should use a compressible model. |
thermodynamic state |
Display Modes | |
Time step dependence of convergence behavior of steady state simulations in CFX | Chander | Main CFD Forum | 5 | December 23, 2013 05:31 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
Water pump OpenFOAM 15 ANSYS CFX 110 comparation | waynezw0618 | OpenFOAM Running, Solving & CFD | 39 | March 5, 2009 12:57 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
is "double precesion output for cfx" default? | charles | CFX | 3 | May 17, 2006 14:40 |
